12-19-2014, 01:22 AM | #21 |
Re: Metal tube that carries the wiring loom to the Cut Out.
I see Mikes Model A has the repro one $18.95
12-19-2014, 02:08 AM | #22 |
Like so many reproduction parts, a one-time run is made and then there are none ! For those of us who have been in the hobby for a number of years, we have seen a great number of reproduction parts that were made for a time, and then no longer made. However, my SACRAMENTO VINTAGE FORD catalog # 24-A, has one on page 274 - IF they still have it.
A recent post on the accessory oil filler pipe 'exhaust tube' provides another example of this. I have both an original "Fulton - FuMaze" and the later reproduction. The later reproduction has not been made for a number of years now. There are LOTS of other examples of repro. parts that are no longer being made. When you see something you like - BUY IT ! Other threads talk about 'hoarding'. But this will help you understand why some of us 'collect' things that may not have an immediate use. - Doug Vieyra Last edited by DougVieyra; 12-19-2014 at 02:17 AM. |
12-19-2014, 03:51 AM | #23 |
Hi
Mine came from O'Neill Vintage Ford in the UK http://www.oneillvintageford.co.uk/ Here's the part number if it helps 1928-30 Cut-Out To Terminal Box Wire A-14406-A
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
12-20-2014, 02:32 AM | #24 |
BRATTON'S catalog for 2014, page 94, bottom right - 1928 thru early 1930. Metal Tubing - "Cut Out to Terminal Box Wire" - $18.25.
BERT'S would also have them, most likely. |
12-20-2014, 07:44 AM | #25 |
Yes we do. Part Number A-14406-A.
Steve Becker Berts Model A 800-321-1931 Modelastore.com |
