Old 12-01-2014, 11:28 PM   #1
flathead47
flathead47's Avatar
Default installing an 8ba into 36 coupe
Starting to plan installation of an 8ba into a 36 coupe. Looking for advise on what is required.
flathead47 is offline   Reply With Quote
Old 12-01-2014, 11:41 PM   #2
Topsterguy
Topsterguy's Avatar
Default Re: installing an 8ba into 36 coupe
I'll be doing the same thing in my 36 coupe later so I'll watch!
Topsterguy is offline   Reply With Quote
Old 12-02-2014, 07:31 AM   #3
mfagan
mfagan's Avatar
I asked the same question a couple of weeks back. There was a good bit
of discussion . Do a search.
mfagan is offline   Reply With Quote
Old 12-02-2014, 08:44 AM   #4
white64
white64's Avatar
tried many searches and found nothing, what should "we" use as key words for this search...?
white64 is offline   Reply With Quote
Old 12-02-2014, 09:07 AM   #5
Tinker
Tinker's Avatar
http://www.fordbarn.com/forum/showthread.php?t=154620
Old 12-02-2014, 12:00 PM   #6
white64
white64's Avatar
Well there! Couldn't be any more simple than that! THANKS!
Must be similar for a '40
Old 12-02-2014, 02:13 PM   #7
Ol' Ron
Ol' Ron's Avatar
The things that make this a good swap are the new water pumps and the use of the SBC dist. Yhe dist will really waike these engines u[. The fan belt hits the old dist.
Old 12-02-2014, 02:23 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
The basic swap itself is fairly straightforward using Ford/Merc parts, but understand, it's NOT similar to a '40, especially when it comes to FAN clearance. The '36 RADIATOR leans back into the engine compartment at a significant angle, whereas the '40 radiator is straight up and down.....'40s are easy. Who has successfully come-up with a mechanical fan on an 8BA in a '36 that actually WORKS, and how did ya do it? We're not talking electric fans, nor converting front of engine to 59-style set-up. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-03-2014, 09:45 PM   #9
flathead47
flathead47's Avatar
Thanks everyone for the information , lot of knowledge on this forum.
I did use the search function as I knew this question had been asked before , but as others have said nothing came up using the search function , I'll try it again.
