Old 11-09-2014, 04:52 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Oregon to Georgia in a 1930 Standard Tudor
BTW, if the cutout is bad you can use a short jumper wire between the input and output terminals to get home. Just be sure to remove the jumper when the engine isn't running.
The same thing goes for a bad ammeter, just jump a wire between the two terminal box wingnuts.
