Old 10-29-2014, 04:20 PM   #1
Scottyboy
Question Flathead exhaust valve guide seals
Are seals used and or needed for the exhaust valves on the 8BA engine?
Thanks
"This thing better run when I get done!"
Scottyboy is offline   Reply With Quote
Old 10-29-2014, 04:31 PM   #2
oldford2
oldford2's Avatar
Default Re: Flathead exhaust valve guide seals
Intakes only. And then use the O'ring type rather than the square ones which are a bear to install without them shearing.
oldford2 is offline   Reply With Quote
Old 10-29-2014, 06:35 PM   #3
Ol' Ron
Ol' Ron's Avatar
I use never seize on the exhaust and RTV on the intakes
Old 10-29-2014, 06:44 PM   #4
oldford2
oldford2's Avatar
Ol Ron,
No seals on either? John
Old 10-29-2014, 08:13 PM   #5
flatjack9
flatjack9's Avatar
I'm with Ron on no seals in either. I use a little hi temp RTV on the intakes.
Old 10-29-2014, 10:24 PM   #6
Ol' Ron
Ol' Ron's Avatar
This is a logical decision I made because the Hi Temp RTV was not available back when Hank designed the flathead. AND, that's a big and, from 32 to 48 Ford never used any seals. Now what you should be concerned with is the valve stem ti guide clearance. THIS, is where the oil is pulled under hi vacuum. I Knurl the guides and ream them for a .0005/.001 fit. The knurel will keep the guide well lubricated. AND yes Knurel the new guides you bought and ream them as well. I've done this to every engine I've build over the past 30 years.
Old 10-30-2014, 02:33 PM   #7
Shu47
Shu47's Avatar
Ol' Ron - The knurling makes sense to me but being an electrical engineer I don't know how it is done. Do you have to take the guides to a shop or can you do it yourself?
Shu47 is offline   Reply With Quote
Old 10-30-2014, 03:43 PM   #8
Ol' Ron
Ol' Ron's Avatar
I do mine in a lathe now, however I did them in a vice with a fixture I made out of wood to hold the guide while I ran the knurling tool, and the reamer. Most auto machine shops should have the tools
Old 06-01-2015, 10:26 PM   #9
Bored&Stroked
Bored&Stroked's Avatar
BTTT: Here is how I just did it:
Here is the problem - all the guides I've ever used are fairly loose in the guide bore. This is something that I 'fix' with knurling. When Ron talks about knurling, he is talking about the traditional knurling of the valve guide bore to tighten up guide bore to valve stem clearances. I know some experienced racers that won't knurl flathead valve guides (especially the exhaust), they install bronze liners. The reason is that they want better heat transfer from the valve stem to the guide and tightly fitting bronze liners do this supposedly better than a knurled cast iron one.
Video: The problem with loose fitting guides (in the block):
https://www.youtube.com/watch?v=qZBXFMqHs-c
Here is the knurling process and final result:
Video: Knurling:
https://www.youtube.com/watch?v=UqYqBIy1BAI
Here are some final guide pictures - you can see my spring spacers for the Isky 185-G springs as well as the cut-back section I do on the top of the valve guides (so they don't obstruct the port).
Enjoy:
Old 06-01-2015, 11:14 PM   #10
Keystone 34 3w
Keystone 34 3w's Avatar
Knurel is a good friend of mine!
Keystone 34 3w is offline   Reply With Quote
Old 06-02-2015, 07:24 AM   #11
Ol' Ron
Ol' Ron's Avatar
I don't bother to Knurell the outside of the guide the RTV takes up the room between the guide and block. However, doilg this will probably center the guide and grinding the seat with the knurelled guide in place will make a true seat. My valve grinding fixture locates on the guide bore.
BUT, we haven't addressed the stem to guide clearance here.
Old 04-22-2024, 08:40 AM   #12
GB SISSON
GB SISSON's Avatar
I'm still wondering what is considered proper stem to guide clearance for 8ba? Not showing up in a search.
GB SISSON is online now   Reply With Quote
Old 04-22-2024, 10:55 AM   #13
petehoovie
petehoovie's Avatar
Video: Knurling:
Enjoy:
Old 04-22-2024, 02:51 PM   #14
Pete
On one hand knurling the outside is good because it makes the guide tight in the block so the valve seat remains solid in place but you also lose about 30% contact area which relates to a LOT of heat transfer capability.
In a street engine you may not notice the shorter life.
