As the title states. Looking to borrow or rent one. I was planning to remove both springs today until you nice people informed me of the potential danger. Please reply to this thread if you're local and wouldn't mind helping out a new guy.
That would be a long one.
It seems like it. I'll give it a week before I buy one from mikes afordable for $70
If you were in my area (Southern California) I would certainly loan you one. Usually a Model A club in your area has one to loan. I would buy a spring spreader. Somewhere down the road you will need it again. When purchasing one be sure you are buying a proper spring spreader. Some suppliers sell what they call a traveling spring spreader or half a spreader. These are extremely dangerous to use. They can launch like a cross bow. That may be why they call them traveling.
The full spring spreader shown in the photo is the economy model and is perfectly safe. They sold for about $60 years ago. I think they are around $100 now. The one with all the bells and whistles sells for $135. These have thrust bearings and feet retainers. They are just easier to use. If you are not familiar with a Model A rear spring approach it cautiously. Some people will advise you to pull the rear with the spring attached. This is a dangerous practice. if the rusted 80 year old center bolt lets go you will have spring leafs 20 feet in the air. Spread the spring with the spreader, remove the rear, collapse the spring spreader and remove it, and then remove the spring. It is not lethal when it is not spread. Tom Endy |
#6 | |
The ones that run $135 have a thrust bearing under each leg to make it easy to turn and have spring loaded leg retainers to keep them from falling out when you are trying to position it. Tom Endy |
Harry K Give me a call 517 522 4492 John
#8 | |
Tom, BTW, I really enjoy your TECH Articles on the Santa Anita A's site. Really helps out this NEWB...
i have both units but the spreader with the bearings is well worth the xtra money. much smoother operation and it stops at the proper distance when fully cranked out
I'll give you a call tomorrow John. Thank you
Most times you don't really need a spreader to remove the front spring, and it's not "loaded" and dangerous the way the rear one is.
The only thing I would add to Tom's posting #4 above is "remove the rear shackle before you remove the spreader" though this was obvious and probably understood. |
#12 | |
#13 | |
Once the rear has been removed from the car with the spring spreader still holding the tension on the spring, collapse the spring spreader and remove it. The spring is then no longer lethal and you can remove it from the car by removing the two U-bolts. There is some amount of tension left in the spring by virtue of the center bolt compressing the leafs together. The tension is negligible. However, it is best to place a C-clamp next to the center bolt only for the purpose of making it easy to remove the center bolt. When re-assembling the spring you should replace the center bolt with a new one. Suppliers sell this bolt twice as long as it needs to be to facilitate pulling the leafs together. It is much easier if you again use the C-clamp to pull the leafs together. Tighten the bolt, make sure the square of the head is lined up to fit into the square in the cross member of the frame. Cut the bolt off below the nut and peen it over to lock it in place. Install it back in the car, install the spring spreader, spread the spring, and install the rear. Regards, Tom Endy |
#14 |
P.m. Sent
