Old 10-07-2014, 01:15 PM   #1
36tbird
Default Flathead cutaway and casting molds
I saw a thread over on the HAMB where Flowmeister and Bruce had posted some neat pics. Maybe they have been on here before, but just in case others like me have missed them, here they are.
36tbird is offline   Reply With Quote
Old 10-07-2014, 03:13 PM   #2
hotcoupe
hotcoupe's Avatar
Default Re: Flathead cutaway and casting molds
new to me, thanx for posting! really cool cut-a-way.
tom
hotcoupe is offline   Reply With Quote
Old 10-07-2014, 03:48 PM   #3
bart78
bart78's Avatar
I've been cleaning up a place for a guy that has a ton of pre war ford stuff. And he has a cutaway of what he says is a 34 transmission. It has a handle to turn the gears inside. It's pretty cool.
bart78 is offline   Reply With Quote
Old 10-07-2014, 06:06 PM   #4
Barry-ct
Barry-ct's Avatar
Cool!
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 10-07-2014, 06:25 PM   #5
Fe26
very cool
Fe26 is offline   Reply With Quote
Old 10-07-2014, 07:53 PM   #6
tubman
tubman's Avatar
You guys are aware that the cutaway engine is a V8-60, aren't you. I'm sure it is very similar to an 85-100 version. When I went to the University of Minnesota in 1960-61, they had one of these cutaway V8-60's on display in the hallway of the main engineering building. In six months, everything remotely removable had been stolen off of it.
Old 10-07-2014, 08:56 PM   #7
Ralph Moore
Ralph Moore's Avatar
No wonder they had a rep for running hot, not much space between the center cylinders and the siamesed exhaust ports.
Ralph Moore is offline   Reply With Quote
Old 10-07-2014, 09:16 PM   #8
38Tudor
38Tudor's Avatar
Very cool !
"Thrifty Sixty"
Ford V8 for 1938
38Tudor is offline   Reply With Quote
Old 10-08-2014, 01:27 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
[QUOTE=tubman;958252]You guys are aware that the cutaway engine is a V8-60, aren't you. I'm sure it is very similar to an 85-100 version. QUOTE]
WHOA there! That cut-away IS NOT a V8-60! The red cut-away engine is a 21 stud. V8-60s only had 17 studs. The big give-away (in this case) is the fact that V8-60s DO NOT have a stud directly ABOVE each spark plug hole, as 21 and 24-stud engines have. Note the V8-60 directly below. It has ONLY 1 (one) bolt/stud directly centered between the two middle cylinders.
Below is a different angle on the red cut-away engine......most-definitely NOT a V8-60! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-08-2014, 02:25 PM   #10
tubman
tubman's Avatar
Ooops! Sorry. It's hard to count studs when so much of the engine is missing. I had a hard time getting to 17!
Old 10-08-2014, 06:57 PM   #11
Talkwrench
Talkwrench's Avatar
Kool cutaway ..
Old 10-09-2014, 09:02 AM   #12
36tbird
They better put an air cleaner on that red engine or the internals are going to get grimy.
Old 10-09-2014, 09:44 AM   #13
Mark Slight
Mark Slight's Avatar
It may not be widely known that the Henry Ford Trade School at the Ford Rouge plant did many of the engine cutaways with the help of instructors.
They were use for displays at new model openings, car shows and in dealer showrooms.
They also ended up in a lot of teaching facility's.
I was there in 1950-1951 & 1952 when the school closed.
Mark (HFTS 1018)
Mark Slight is offline   Reply With Quote
