Old 09-19-2014, 09:45 PM   #1
hb32
hb32's Avatar
Default 1932 Ford signal lights
I know they did not come with them but decided to add them to my pickup.
Rears are straight forward but looking for ideas on fronts.
I was thinking of using a pair of Guide 682c`s and incorporating the markers for signals but really like the look of commercials.
I have seen the aftermarket repro 32 lights with the signals built in and wondering how effective are they?
Not having a whole lot of luck on image search with google...anyone?
hb32 is offline   Reply With Quote
Old 09-19-2014, 09:54 PM   #2
325w
Default Re: 1932 Ford signal lights
Guides will not look real good on your truck my opinion. How about using fog type lights with one circuit a turn signal.
325w is offline   Reply With Quote
Old 09-19-2014, 09:59 PM   #3
deuce_roadster
deuce_roadster's Avatar
On my roadster, I used two bulb headlight reflectors and put a signal bulb in one of them for turn signals. They work fine even when the headlights are on.
Old 09-19-2014, 10:02 PM   #4
Andy
I have used the cowl lights for turn signals. The fronts are not as important as the rears. I use relays to do the switching so no big clunge on the column. Just a very small switch to ground the relays. I like the fog light idea a lot.
Andy is offline   Reply With Quote
Old 09-19-2014, 11:31 PM   #5
hb32
hb32's Avatar
Thanks and keep them coming. How good would the stock style commercials work on 6 volt ?
Old 09-19-2014, 11:50 PM   #6
HemiDeuce
HemiDeuce's Avatar
I've used the turn signal lights mounted inside the original light reflectors and found that they were very visible with the orange bulbs.
HemiDeuce is offline   Reply With Quote
Old 09-19-2014, 11:51 PM   #7
Ralph Moore
Ralph Moore's Avatar
I put a pair of early Harley Davidson turn signals on my hot rod and they look like they belong there .
Ralph Moore is offline   Reply With Quote
Old 09-20-2014, 12:17 AM   #8
Charlie Stephens
I would mount a set of driving lights on the front bumper and use them as turn signals. Cowl lights are just too much ginger bread for a commercial. FYI, I have a '31 RDPU.
Charlie Stephens
Old 09-20-2014, 08:06 AM   #9
Krylon32
On my last truck I found a set of fog lights with the same shape as the headlights and put amber beams in them, they were very visible.
Krylon32 is online now   Reply With Quote
Old 09-20-2014, 09:21 AM   #10
TJ
TJ's Avatar
I used KD-866's on my last car. They are a good looking fog light and you can't miss them when the signal is on. I also used a toggle switch made by American Auto Wire that is specifically for turn signals. It's easily hidden under the dash.
Old 09-20-2014, 01:11 PM   #11
2ndgeer
2ndgeer's Avatar
This topic came up a while ago. For those who install the signal light in the headlight there is a more effective (brighter, more visible to oncoming cars) way than using the stock parking light position. Get single-bulb reflectors from Bob Drake or other supplier and the signal light kit from Parr Automotive. I installed these lights in my '34 and am pleased that I don't have any "add-ons" hanging out front.
2ndgeer is offline   Reply With Quote
Old 09-20-2014, 04:36 PM   #12
hb32
hb32's Avatar
thanks for the picture and information.
This is probably the direction I will take as well.
