Old 09-06-2014, 06:41 PM   #6
Ken Crans
Ken Crans's Avatar
Default Re: F-1 ignition switch install - Suggestions?
Keep even amt. of pressure on the switch and have orientated slightly so when you snap on bezel and twist at the same time to make key in vertical position.. it's a bitch but will work make sure that the insert for the key has a slight amt of grease and moves free. Good Luck.
Ken Crans is offline   Reply With Quote
