#21 |
I have never needed a charger. Batteries last 6-8 years, everything stock, always starts. Normal group on batteries from Advance, etc.
#22 |
i used to use a maintainer over the winter on my chevette... was until i went to start it one spring and got a few clicks and that was it. battery charger when hooked up would show trickle for awhile then switch to fully charged. apparently was not charging at all...
now i just leave the battery disconnected from the car and charge it on 2a setting with a normal charger for an hour before i start it in the spring. cranks right over just normally.
#23 |
Get a 6 volt DC 300mA power supply from an old cordless telephone or what have you and use that as a battery maintainer. Put it on the battery once a month for a few days, your battery will stay like new. Make sure you get your polarity correct.
#24 |
Thanks for all the replies. My main need is for a 1995 Buick that sometimes sits for a month or more without being driven. That car has a continuous small battery drain that is used for some of the electronics.
My current thinking is to get a Battery Tender Junior. I think that it is not likely to cause trouble because it is dedicated to 12 volts and delivers a maximum of 0.75 amps. Also claimed to shut down / off when battery charged. |
#25 |
Battery Tender with battery disconnected thru a voltmeter.
6.2v gets plugged in, 6.7v gets un-plugged. Working very well with a standard Deka battery. ![]() Side note....the 'Script' tar top battery split while sitting on the bench in the basement, no charger involved, just poor construction. ![]() Bob
..."they are only original once" |
#26 |
The 14.4 volts seems undesirably high to me. I think that I will get one of these, but try to turn it off manually when the voltage gets to 12.5 or so. If I leave it unintentionally longer, the automatic float feature will offer protection. |
#27 |
Richard,
Our 'Burb is used mostly for towing, it sits quite a bit. I have 12v Jr connected thru a power port, the BT light shows green & rarely do I see 13v, usually 12.8. Pretty much the same for the 6v, 'cept it's connected directly to the battery, with the negative cable off. I've seen a max chg voltage of 6.75. Un-plug and start over at 6.2. Bob
#28 |
I have a Schumacher for about $18. I disconnect the battery ground cable, hook up the Schumacher, and fly back to Texas for seven months. The next spring when I return the battery is fully charged. Cranks right up. If the charger is over charging, the top of the battery will be wet and have low electrolyte level.
#29 |
love my battery butler...five tears and counting.....no problemo
#30 |
I use a Save a Battery - Vehicle Battery Chargers. 100% automatic. Plug and Play. Features state of the are PULSE technology. SLA. AGM. Dry Cell. Spiral Cell. GEL.
See www.saveabattery.com for more information |
