Old 08-11-2014, 02:26 PM   #1
Richard Lorenz
Default Trickle Battery Charger
What I want is a low amp battery charger that will cut itself off completely when the battery becomes fully charged. This will be sort of a "maintainer".
I tried a Schumacher 6/12 volt charger that used vague language to suggest that it would do the above. I tried it on 2 different batteries and it never shut off. It appeared to be over-charging the batteries, so I returned it to the seller.
Is there any "maintainer" charger that really completely stops the charging when the battery becomes fully charged?
Richard Lorenz is offline   Reply With Quote
Old 08-11-2014, 02:32 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Trickle Battery Charger
I would prefer to plug any low amp charger into a timer.
Old 08-11-2014, 02:40 PM   #3
mshmodela
mshmodela's Avatar
Sears sells a 12/6 V auto select low current charger ~2A I believe... that does just that.... I got mine for ~ $25... Works well on my 6V battery and got my Mrs. 12V back in shape after the lights were left on...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-11-2014, 03:04 PM   #4
Keith True
Keith True's Avatar
I am very leery of any charger that says,automatic,floater,maintainer,or smart charger.One little tickle from a thunderstorm and the sensitive parts seem to become solid circuits.Anything that has little lights to tell state of charge make me nervous.Same thing with chargers that say they will shut off when battery is fully charged.They may do it when new,but once they've been dropped they seem to just keep charging.I've had two real serious problems with the Deltran maintainers.The company got back to me a few months after I contacted them,they said if somebody tries to start the car with the maintainer still hooked up the sensors could get fried.One had a meltdown sitting on the top of a Wheelhorse tractor,the other one I had hooked up to four batteries in a Brockway.Batteries were in parelell,and I left the maintainer hooked up to them for a week.I walked into the shop one morning and there were pieces of battery all over the place.Turns out the thing never shut off like it was supposed to.Is there a reason you feel you need a maintainer? If you have a drain,you have something that needs to be fixed.
Keith True is online now   Reply With Quote
Old 08-11-2014, 03:06 PM   #5
ModAfan
ModAfan's Avatar
I have used Battery Tenders - 6 and 12 V models - for years without a single complaint. They cannot overcharge.
ModAfan is offline   Reply With Quote
Old 08-11-2014, 03:10 PM   #6
smittykid
smittykid's Avatar
Smile Re: Trickle Battery Charger
I have been using the Deltran Battery Tender Junior on most all of my batteries. It's a float charger and only charges when the battery needs a little boost. I have had these battery tenders connected to almost everything I own with a battery in it. Cars, trucks, ATV's , riding lawnmowers, etc. They make a 6 volt version and I am going to use one on my new Model A. I have been using a 6 volt unit on my 52 Jeep for 4 years with no battery problems. Auto parts stores carry them, but I have found the best deals on eBay. Smitty
smittykid is offline   Reply With Quote
Old 08-11-2014, 04:06 PM   #7
nickair
nickair's Avatar
I have used a "Battery Tender" for 8 years.
7 years was with the same battery. Replaced the battery because I thought I was pushing my luck, but the battery still worked fine.
When I was not driving or working on it, I had the battery tender hooked up.
http://www.amazon.com/Battery-Tender...ry+tender+plus
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
Old 08-11-2014, 04:16 PM   #8
Brother Hesekiel
Brother Hesekiel's Avatar
I have trickle chargers on all of my collector cars and bikes. I went that route after I had to buy 3 brand new Harley-Davidson batteries in only 2 years because I didn't use the damn bike. Since then I actually use the cheapest and lowest power motorcycle chargers, even on my Model A. It charges only 0.5 amps per hour, which is fine for what it's needed.
Brother Hesekiel is offline   Reply With Quote
Old 08-11-2014, 04:47 PM   #9
sky1928
Try Battery Butler - They have both 12v and 6v versions.
sky1928 is offline   Reply With Quote
Old 08-11-2014, 05:49 PM   #10
Tom Endy
Tom Endy's Avatar
I also have one of these Sears Die-Hard chargers and they have some excellent features. It has no on\off switch, but it will not automatically turn on until it is connected to and sees a battery. If a lead should fall off it shuts off. When the battery is fully charged it shuts off. Works on both 6 and 12 volt batteries. Switch to 6-volts and it charges at 4 amps, switch it to 12 volts and it charges at 2 amps. Comes with battery clamp cables and a cable with a device you can plug into the power outlet (cigarette lighter type) on a modern car.
Tom Endy
Old 08-11-2014, 06:12 PM   #11
billwill
Atimer will cut the amountof curciut going to a charger good luck
billwill is offline   Reply With Quote
Old 08-11-2014, 07:53 PM   #12
SDJason
SDJason's Avatar
I've got one of these, and USED to leave it plugged in all the time - until I found out the hard way that the battery was slowly being overcharged (meaning a bunch of acid seeping out the top).
Now, I just hook it up every month or so until it transitions from charge to trickle (the led turns from red to green), indicating that the battery is fully charged.
SDJason is offline   Reply With Quote
Old 08-11-2014, 07:54 PM   #13
JEC
I have 6 and 12 volt Battery Tender's and a 6/12 volt Black and Decker that I bought at Home Depot for a really low price. They all work well and will charge up a low battery if you are willing to wait for a couple of days.
JEC is offline   Reply With Quote
Old 08-11-2014, 10:20 PM   #14
racer32
Me too. I don't leave them plugged in constantly, though.
racer32 is offline   Reply With Quote
Old 08-11-2014, 11:59 PM   #15
Mike V. Florida
Mike V. Florida's Avatar
I too have used a "Battery Tender" for years.
As mentioned you can also place a regular charger on a house light timer.
Old 08-12-2014, 09:22 AM   #16
townsedan29
Ive used a shumacher maintainer (8 of them) for many years no issues. battery always charged and the atv and 6 volt batterys last much longer
townsedan29 is offline   Reply With Quote
Old 08-12-2014, 09:24 AM   #17
Paul from Maine
Paul from Maine's Avatar
My Montgomery Ward 12/6 volt 8 amp charger has a manual timer on it which also works as an on/off switch. Twist the knob to the number of hours you think necessary and it shuts off by itself! Also has an analog meter to show how many amps the battery is willing to take! Bought it for five bucks at a garage sale!
Paul from Maine is offline   Reply With Quote
Old 08-12-2014, 11:54 AM   #18
William Kelchner
William Kelchner's Avatar
I too have had pulse mode battery maintainers on both my old vehicles, both 6v and 12v for years, 24x7-365 and have had zero problems. Love em.
William Kelchner is offline   Reply With Quote
Old 08-12-2014, 02:12 PM   #19
Skibb
Skibb's Avatar
Mine is from Walmart - wonderful item.
Skibb is offline   Reply With Quote
Old 08-12-2014, 02:26 PM   #20
BlueSunoco
Power Tender here too. Used for many years no problems. 1.25 amps
Probably not a bad idea to use a timer I'll give that some thought.
Also, like to have the batteries out of the vehicle sitting across the garage on a shelf.
BlueSunoco is offline   Reply With Quote
