Is anyone using a 3.54 rear gear in a 46 to 48 convertible? Is this car to heavy for this gear? Like to hear any Pro or cons. The car has a 4.11 installed in now ..... Thanks
to start with it would be helpful if you would go back and update your profile, mostly as to what city and state your in, in calif ,might be a little high for states that have a lot of mountains, Nevada or any states that are mostly flat that gear will be alright, hiway or city driving your good, so let us know where your at and then we can give a little more exact advice, 4:11 gears are usually found in over drive cars
Probably the best assessment was by Tom McCahill in an original road test...this link I found on here has excerpts: http://auto.howstuffworks.com/1941-1...er-deluxe8.htm
I have the original magazine somewhere. He was mostly a Ford fan in his views, and a year or two later than this wrote up an article on having the 239 in his own '49 or '50 Ford rebuilt by Granatelli...making it faster than the '49-'50 Cadillacs he had tested for only a few hundred dollars. |
im maybe mistaken but didn't 46-48 mercs come with 3. 54 rear and 15" tires
I run a 355 15 inch tires with a5 speed love it
For whatever it's worth, wife & I have a 46-48 convert (47F), and it came with 3.54's. In my opinion, it's a slug to drive, sluggish off the line, won't keep up on freeway on-ramps. Once going, it's ok. And, at freeway speed, it sounds 'busy', and I would like a taller gear. So, this is a 'non-answer'. I'd like taller highway gears, and lower stop-sign gears. IE, I'd like 3.78's and an overdrive. Or, maybe just a T-5 or similar. JMO
I have 3.54 gears in my `35 cabriolet with 16" wheels and it seems to be a perfect set up for me here in the hill country of West Virginia. The engine is a stock 21 stud and I can run 70 on Interstate. But I am sure my car weighs less than yours.
Son, you will never blow an engine up in high gear. |
This is why FoMoCo went to the Borg Warner electric overdrive in 1949. Lincolns had been using them for years and they were really good for town driving just using 2nd gear & 2nd/OD for putting around town. You only needed to clutch at the stop signs. Most used the 3.92:1 gearing or there abouts. Mountain driving was better with 4.11:1.
3.78:1 has always proven to be the best overall gearing for cars with no overdrive or Columbia 2-speed axles. |
My 46 Coupe has 3.54 and with the 16 inch wheels, it is an excellent cruiser on the freeway.
If it aint broke, don't fix it! |
#12 | |
Super Moderator
The 3:78 is in my opinion the best "overall" gear set for your car. Gets the car rolling "off the line" with little effort and can be driven without stress on the engine up to 65MPH or so. No doubt as fast as prudent with a 1946 designed brake system. The 3:54? Unless you live on a flat plain, forget it. The car is simply not powerful enough to get it rolling along well. Yep, the 3:78... go for it. You'll be pleased!
#13 |
AGREE X2. My '46 convertible has 3:78 and it is the best all around gearing for town & country driving.
#14 |
Thanks for all the replys ..... I updated my profile ... Bruce , the Tom McCahill road test is a good read on the difference ... appears the 3.54 may not be the best overall choice for this car as those who have it indicate a slug off the line ..... those with 3.78 appear to like the better overall performance ... I do have a set of 3.78 gears I could install , so I will do that. Down the road if I find a columbia or Lloyd Young overdrive the 3.78 will work with them as well. I thought about the Mitchell OD but do not want to cut the floor for clearance .....
#15 |
I have 354 in my 35 Pickup and my 40 Ford. They are super. I run 55 with ease and I live in the mountain area. They are no problem.
#16 | |
We have a Mitchell in our 46 four dour and no floor mods required. Not sure on your convertible. Have the cable shift as the lever shift would involve cross member changes. Love it. John |
#17 |
One way to get a wider range of gearing (easy off the line but decent cruising speed) without going to a 5 speed or over drive would be to use a set of pickup gears (29 tooth cluster) with a "high speed" rear. Wouldn't be a hot performance combination, but it should make everyday driving pleasant. IMHO!
Don't never get rid of nuthin! |
#18 |
flathead 47 if you can find a volvo overdrive unit you can pick one up quite resonably. i had several of them and the most expensive one was 350 bucks. the unit is quite small and there has been some articles on here on how to put one in a torque tube. no levers they are electric solenoid. go real well with a 393 gear
#19 |
The 29 tooth cluster and 3.54s would get you going, and drop the r's on the highway as recommended by PETEVS. Anyone have some real experience with that combination ?
#20 |
my 46 coupe with headers and duals and merc crank has 3.54 gears and a columbia and i love it. i live in southern wisc.
