06-29-2014, 09:29 PM | #1 |
radial tires
I am thinking of putting 600x16 radial tires on a 36 Ford pickup with original steering gear box. Does anyone know how the pickup would handle with the installed? Is this a good idea or not?
Thank you |
06-29-2014, 10:04 PM | #2 |
Re: radial tires
The single best thing you will ever do to your 36 will be to fit radials!
Unfortunately, two half wits don't make a whole wit! Last edited by Brian; 06-30-2014 at 01:25 AM. |
06-29-2014, 11:09 PM | #3 |
Re: radial tires
I absolutely agree. I did this on my '51, and it made all the difference in the world.
06-30-2014, 01:21 AM | #4 |
Re: radial tires
I don't have a '36, but they sure made a big difference on my '40 Sedan. I went with Cokers and pretty happy with them. Good luck.
Mike |
06-30-2014, 06:55 AM | #5 | |
Re: radial tires
I put Diamondbacks radials on my 36 3window & it most certainly improved handle & steering . I will never go back to bias tires Bill |
06-30-2014, 07:22 AM | #6 |
Re: radial tires
Imagination is more important than knowledge. |
06-30-2014, 08:23 AM | #7 |
Re: radial tires
I have radials on my 49 and bias on my 41 and while I agree the radial eliminate the tendency to follow every ruthless in the road they make parking a pain. When parking with bias you feel like you have power steering but with radials you know you don't.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
06-30-2014, 09:22 AM | #8 |
Re: radial tires
I forgot to mention that I run the radials at 40psi, that makes them more user friendly when trying to park, parallel or otherwise...
