Old 06-05-2014, 01:14 PM   #1
Dick C
Dick C's Avatar
Default Horn keeps blowing 51 Ford car
Everything I go over a bump the horn blows. I have to move the horn ring to get it to stop. Took it apart and couldn't see anything wrong.
Dick C is offline   Reply With Quote
Old 06-05-2014, 01:29 PM   #2
41ford1
41ford1's Avatar
Default Re: Horn keeps blowing 51 Ford car
The wire that runs down the inside the column from the button to the bottom of the steering box is most likely shorting out.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 06-05-2014, 01:30 PM   #3
green50
green50's Avatar
Check the wire that runs down through the steering column. If it's the original wire it could be worn through and is shorting out, causing the horn to blow.
Gene
green50 is offline   Reply With Quote
Old 06-05-2014, 01:48 PM   #4
Dick C
Dick C's Avatar
Checked out wire and it looks ok. Not worn through any place.
Old 06-05-2014, 02:03 PM   #5
Mart
Mart's Avatar
Can you see the horn ring moving as you go over a bump? Is it like it is on a hair trigger where it blows with the slightest movement?
Old 06-05-2014, 02:03 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
It's pretty obvious that the horn ring grounding points are not keeping a proper air gap. Could be bent or loose. Only you have the ability to determine that.
Old 06-05-2014, 02:30 PM   #7
Vonn Ditch
I think you may have a clown in your car somewhere.
Vonn Ditch is offline   Reply With Quote
Old 06-05-2014, 04:19 PM   #8
Dick C
Dick C's Avatar
Yes it's like a hair trigger. Still everything looks ok and tight. Sounds crazy.
Old 06-05-2014, 04:30 PM   #9
green50
green50's Avatar
You may have to check over the wiring, you obviously have a short somewhere. Good luck!
Gene
Old 06-05-2014, 08:03 PM   #10
nstegall
Dick,
You say the ring is a hair trigger. Well, that is your problem. It is misalined or there is not enough tension on it to maintain the proper air gap. Simple solution. Good luck with it.
Neil
THE HORN MAN
nstegall is offline   Reply With Quote
Old 06-05-2014, 08:29 PM   #11
Rand
Rand's Avatar
I've heard of the horn shorting out and shocks your arm as your cruising down the road looking cool with your arm resting on the window trim....let's hope that doesn't happen .ha...ha
Randy
Rand is offline   Reply With Quote
