Old 05-27-2014, 07:53 PM   #26
Henry Floored
Henry Floored's Avatar
Default Re: New Flathead Engine
Originally Posted by Wily Kyote View Post
Is this the pan off the China flathead? The transmission bolt pattern isn't even the same. Compare to the Ford bolt pattern on the right.
Not to change the subject but that trans adapter on the right looks like a small block Ford to early Ford trans. Am I right? If so is that a new product? Can you tell us more about it?
Henry Floored is offline   Reply With Quote
