Old 02-18-2014, 10:42 AM   #1421
BILL WZOREK
BILL WZOREK's Avatar
Default Re: What I Did on My Lunch Hour
Not saying that just: I had trouble understanding your explanation of how on the old cars the spedo is not real accurate till it comes around for the 2nd time.
>> ZOOM ZOOM <<
BILL WZOREK is offline   Reply With Quote
Old 02-19-2014, 08:41 AM   #1422
Vic Piano
Vic Piano's Avatar
Bill, did I also explain how Convertibles go twice as fast as closed cars...??? Or maybe it just feels that way...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 02-21-2014, 09:00 AM   #1423
Vic Piano
Vic Piano's Avatar
I picked up the rebuilt starter for the '39 LZ yesterday and installed it however, the Optima battery was low so I put it on trickle charge for a few hours... Still not strong enough to crank the V-12 fast enough for it to fire... Think I'll take the Optima and have it tested and, if necessary, pick up a new battery (the Zephyr was converted to 12 volts before I got her). I also took the generator to have it converted to 12 volts, the car has a one wire alternator on it, and I want to put the generator back with a voltage regulator because, from an astatic standpoint, I don't like the way the alternator looks on a Flathead, to me its like a fish out of water...
Old 02-21-2014, 02:50 PM   #1424
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Vic Piano View Post
".......because, from an astatic standpoint, I don't like the way the alternator looks on a Flathead, to me its like a fish out of water...
Can we safely assume that you meant "aesthetic"? Just curious! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-21-2014, 03:08 PM   #1425
Vic Piano
Vic Piano's Avatar
Hey Coopman, You are correct! I meant to write aesthetic, I didn't catch that this morning when I posted it however, astatic could also apply as, in my opinion, an alternator looks unstable sitting atop a Flathead intake manifold. Thanks for pointing out the error, and for continuing to drop by my thread.
Old 02-21-2014, 03:36 PM   #1426
V8COOPMAN
V8COOPMAN's Avatar
I could suppose it to look unstable (astatic) if it were possibly attached with baling wire. DD
T5 W/TORQUE TUBE
Old 02-21-2014, 05:33 PM   #1427
Vic Piano
Vic Piano's Avatar
Well, that's your opinion, and you are certainly entitled to it. Its my opinion, and I'm entitled to it as well, that alternators look out of place on Flatheads, regardless of the method of attachment. I have both 6 and 12 volt generators (where applicable) in use on several of our Flatheads that are driven daily (and night time too) and I've never seen the need to install an alternator. The only reason I have an alternator on the '39 LZ is because the previous owner installed it. I must say, I'm surprised that you would be in favor of someone installing a non authentic part on a Flathead... What would the judges say...?
Old 02-21-2014, 06:12 PM   #1428
B-O-B
B-O-B's Avatar
Why don't cha just put aZIPPER inda ZEPHER ha ha ha
B-O-B is offline   Reply With Quote
Old 02-23-2014, 11:07 AM   #1429
Vic Piano
Vic Piano's Avatar
Here's a question for you Woody aficionado's. I've got a line on a '39 Standard Woody and I'd like to know if there are any specific things I should look for, with respect to the wooden body parts, to determine if the asking price is realistic based on the overall condition. As always, help is appreciated.
Old 02-24-2014, 06:37 AM   #1430
Vic Piano
Vic Piano's Avatar
Yesterday I made what I consider a valiant attempt to clean the garage, in preparation for the Florida "Barner's Bash" this coming weekend. I did make some progress with the garage but, more importantly, I've got four of our Flathead powered vehicles running and ready to cruise. Now all I need to do is wash them before Friday...
Old 02-26-2014, 08:50 PM   #1431
Vic Piano
Vic Piano's Avatar
While its true that you could, and maybe should, learn something new everyday, of late, I think I've been forgetting things I've learned along the way, especially things that are relevant to Flatheads, at an alarming rate... for example, I installed the '39 LZ carb without checking the fuel pump to confirm adequate fuel delivery. As a result, It took an inordinate amount of time and vast quantities of fuel poured down the carb, while trying to get the fuel pump to prime it. This is after I removed the air horn and filled the float bowl with gas... As a result, I'm fairly certain that my overzealous applications of fuel caused the PV to malfunction... I came to this conclusion when I attempted to adjust the air/fuel screws... All the way in, or all the way out, produced no discernible change in the carbs behavior. From every bit of knowledge I've gleaned after years of messin' with Flatheads, I surmised the PV to be the problem. I confirmed my suspicions by conferring with several well known Flathead carburetor aficionados'. The consensus; a toasted PV. The good news is a new PV, etc. is on the way. The bad news... it looks like I won't have the '39 LZ on the road for the Florida "Barner's Bash"... I guess I really did learn, or re-learn, something today. Now, if I can retain that tidbit for a while...
Old 03-04-2014, 06:08 PM   #1432
Vic Piano
Vic Piano's Avatar
Now that the 2014 Florida "Barner's Bash" weekend is history, I can focus on the Flatheads in the garage once again. But first, we are going to the Amelia Island Concours d' Elegance this weekend for some R&R...
Old 03-04-2014, 06:34 PM   #1433
41ford1
41ford1's Avatar
The 2014 Bash was a great time. We really enjoyed it. You and the Cigar City Flathead crew did an excellent job on setting it up.
Enjoy the Amielia Island event. Take lots of pictures.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 03-05-2014, 06:29 AM   #1434
Vic Piano
Vic Piano's Avatar
Thanks Chuck, I appreciate that. I'll post some photos from Amelia next week. Stay warm.
Vic
Old 03-09-2014, 07:26 PM   #1435
Vic Piano
Vic Piano's Avatar
We just got home from three days at the Amelia Island Concours d'Elegance, I think this year's show was the best one yet. There were some beautiful Flathead V8's, etc. Tomorrow I'll post some photos for the Fords & Lincolns.
Old 03-10-2014, 06:38 AM   #1436
Vic Piano
Vic Piano's Avatar
Here are a few photos from the weekend. First is a Pininfarina bodied '32 Ford.
This is one of the Sleeping Bear Resort Dunesmobiles.
Here is an interesting Tri-Power set up on a Packard.
A '47 Sportsman.
Here's a question for Sportsman owners: What is the chrome piece on the top of the quarter panel for?
Old 03-10-2014, 06:51 AM   #1437
Vic Piano
Vic Piano's Avatar
A few more...
In addition to the Flathead V8 Fords, there were dozens of fantastic vehicles on the show field and in the auction. I'll be happy to post more if you're interested.
Old 03-10-2014, 07:34 AM   #1438
GaryTx
GaryTx's Avatar
Vic, The chrome pieces cover the joint between those pieces of wood. It's like an expansion joint. Gary
GaryTx is offline   Reply With Quote
Old 03-10-2014, 08:02 AM   #1439
Vic Piano
Vic Piano's Avatar
Gary, That's interesting. I couldn't see any wood on the inside, and the quarter window and channel are between the exterior wood and the interior quarter panel. I know that in our '47 Convertible (not a Sportsman) the inner quarter panel covers the strut and braces for the top mechanism along with the window regulator. The position of the chrome escutcheons (for lack of a better description) is, as far as I can tell, nowhere near any wood...? I can't recall ever seeing the escutcheons on any other Sportsman, Ford or Mercury...
Old 03-10-2014, 08:08 AM   #1440
oldbugger
oldbugger's Avatar
Vic, Nice pictures, I would be interested to see more. Neat to see the dune car, we live a little south of there and have visited many times. amazing those cars were able to get around in the sand. Paul
oldbugger is offline   Reply With Quote
