Old 03-02-2014, 10:11 AM   #1
keeeef
Default Crossmember Rivets
Just wondering why crossmembers were riveted and not bolted in. Just bought a used rear crossmember for my 36 pickup and don't have much experience of rivetting.
keeeef is offline   Reply With Quote
Old 03-02-2014, 10:32 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Crossmember Rivets
Rivets are much stronger than bolts and of course have much less tendency to loosen when the frame flexes.
Kube is online now   Reply With Quote
Old 03-02-2014, 11:37 AM   #3
rotorwrench
rotorwrench's Avatar
Just to add, rivets expand when squeezed or bucked and fit the bore of the drilled hole much more securely than a bolt. Many steel bridges and buildings that were constructed with rivets over a century ago are still standing and in use today.
In aviation, pins and bolts are utilized more now than ever before but the bore of the drilled hole is reamed to fit the pin or bolt tightly and small increment oversizes are available to repair these if they become loose in service.
Hanson Rivet has all sorts of replacement rivets and they can be heated with a torch to make bucking the rivet easier but they aren't easy for the larger sizes and special equipment has to be either purchased or fabricated to aid in bucking or squeezing them. It helps if you have like minded friends who can get together and do multiple jobs at one time so as to have the help it takes to move and position frames and such for best access & grip on the big pneumatic air hammers and bucking bars.
Old 03-02-2014, 01:28 PM   #4
ford38v8
ford38v8's Avatar
Big Flats Rivet Co www.bigflatsrivet.com
Authentic rivets for vintage cars
Alan
Old 03-02-2014, 01:41 PM   #5
john in illinois
john in illinois's Avatar
I learned a great way to heat rivets helping a friend put in a crossmember.
Put the rivet in the hole cold and position bucking bar. get a stick welder cutting electrode-ours were from harbor freight. Turn the welder up to about 180amps-may vary. Touch the electrode to rivet end and the entire rivet heats completely through. Cherry to white hot. Then hit it with the air gun.
A lot simpler than using a torch and sure expansion in the hole.
John
john in illinois is offline   Reply With Quote
Old 03-02-2014, 01:53 PM   #6
PeteVS
PeteVS's Avatar
John
OK, so you're saying to put the rod onto the end of the rivet and hold it there without creating an arc? How long should it take to heat up a 1/4" rivet?
Old 03-02-2014, 02:09 PM   #7
ford38v8
ford38v8's Avatar
Blink three times.
Alan
Old 03-02-2014, 08:10 PM   #8
PeteVS
PeteVS's Avatar
Has anyone used this method for shrinking sheet metal?
Old 03-02-2014, 08:55 PM   #9
Torchie
I have heard of people doing some thing like this. Would have to be cautious not to burn thru the sheet metal I would think.
Also have heard of people using a MIG welder with the gas shut off to create a hot spot as well. I can't claim to have done it myself.
Torchie.
Torchie is offline   Reply With Quote
Old 03-02-2014, 09:09 PM   #10
Ed Pitts
Ed Pitts's Avatar
A gas torch and a wet rag will work on shrinking metal. Ed
Ed Pitts is offline   Reply With Quote
Old 03-03-2014, 03:58 AM   #11
dumb person
dumb person's Avatar
Tell me more about this arc welder method plz
i have used an arc welder to shrink sheet metal but it is not preferable to heating with gas.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 03-03-2014, 08:26 AM   #12
john in illinois
Pete when you use a cutting rod made for cutting steel with an arc it does not deposit any metal. You arc to the rivet and it is instantly hot. Then you drive it.
John
Old 03-03-2014, 12:55 PM   #13
Bruce/CT
John,
Thanks for the great tip. I have Rivets and Riveting Air tool from Big Flats but couldn't figure out how I was going to heat the Rivets. What stick welder do you recommend? I have a MIG & TIG but no stick and have to do some riveting soon.
Thanks,
Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 03-03-2014, 01:04 PM   #14
JWL
Rivets are NOT stronger than bolts. However, properly installed rivets can be crushed tightly into non-precision holes which tends to reduce movement or "working" at the joint. A very desirable circumstance for a crossmember attachment.
JWL is offline   Reply With Quote
Old 03-03-2014, 01:12 PM   #15
Mart
Mart's Avatar
Keef, You don't HAVE to rivet the crossmember in. As your truck is somewhat non-stock you could bolt it in and back the bolts up with some strategically placed welds. Or just weld it in completely.
Mart.
Old 03-03-2014, 02:55 PM   #16
keeeef
Thanks guys for all the suggestions. I had a couple of small cracks in the crossmember and lots of help in a previous thread. I ended up drilling small holes to stop them spliiting further, deep v'd the cracks and welded them up with the recommended 'soft' mig wire. Then wandering round a swapmeet here in the UK yesterday I found a perfect '36 crossmember for sale at £10!!
I only have a mig so no way of heating up rivets unless I get help. Might try Mart's suggestion of bolting and welding as it's not a restoration project more of a get it on the road and use it truck or may run it this year with the repaired crossmember and keep a close eye on it.
Thanks again, always get great advice on the Barn
Old 03-03-2014, 05:42 PM   #17
36tbird
You can use some button head bolts to simulate rivets, at least on one side.
36tbird is offline   Reply With Quote
Old 03-03-2014, 07:20 PM   #18
Fe26
True. Another way of looking at this is, rivets are made from Low Carbon (soft) steel. Rivets are designed and strategically placed to allow the riveted members to flex. Their used to be a field of Heavy Engineering that dealt with rivets, their size, application, layout and spacing, sadly all that knowledge is gone now.
Fe26 is offline   Reply With Quote
Old 03-03-2014, 07:55 PM   #19
Binx
You'll be okay if it is for road use and not uneven terrain. Remember, for every rivet removed and a bolt installed, the missing shear strength of the compressed connection will transmit through some of the frame's rivets so keep it on paved roads and you'll be fine.
Lonnie
Binx is offline   Reply With Quote
Old 03-04-2014, 12:14 PM   #20
rotorwrench
One thing a person should keep in mind is that a bucking a hot steel rivet in effect is a forging process that closes the metals bond structure up a bit during the process. I would venture that they are not much softer than a grade 5 type bolt since both can be easily drilled with a high speed steel drill bit. They put enough of them in the frame gusset locations and for braces to strengthen the joints pretty well. You can use bolts, but bolts will loosen in service unless they fit the hole very tightly and even then, they should be periodically retorqued. Those old frames flex a lot more than modern ones.
