Old 01-26-2014, 07:05 AM   #31
Sixseven
Sixseven's Avatar
Default Re: My 1941 Ford 1/2 ton pickup restoration
I have reread your post and see that you created a truck from several. You have successfully repaired rusted areas on the cab and left most of the cab exterior looking original in color. From your example I think I could do the same, leaving the old patina as it is called. thanks for your explanations.
Ken
Sixseven is offline   Reply With Quote
