Go Back   The Ford Barn > The Archives > Early V8
Old 03-30-2005, 11:54 AM   #1
Guest
Posts: n/a
Default 38 coupe parcel shelf
My coupe ute seems to be missing the parcel shelf lip which prevents parcels etc. sliding off. I am pretty sure I can see such a lip in Mallast's 38-39 Ford Book, Pg.3-22.
Could someone give me a brief description so that I can make something similar ? E.g. Is it solid wood, ply wood or sheet steel? Is the top edge rolled or shaped ? are the ends squared off or rounded? Any info would be helpful.
Old 03-30-2005, 01:55 PM   #2
Guest
Posts: n/a
Default Re: 38 coupe parcel shelf
On my 39 coupe the lip is 53 inches wide by 3 1/4 inches high.
Made of natural wood & is screwed to the front of the plywood parcel tray.
Regards
Chris. NZ.
Old 03-30-2005, 06:00 PM   #3
Guest
Posts: n/a
Correction.
Lip sits on top of the edge of the parcel tray & is attached by several screws from beneath.
Regards
Chris. NZ.
