Old 01-22-2014, 05:09 PM   #61
Bob in Ga
Bob in Ga's Avatar
Default Re: 1932-34 Model B Four Cylinder Group started!
My car is now a member of this group. Have over 10k miles on the B engine in my 31 Slant-windshield model in the past 6 yrs. Just finished a brake job last wk. Now to do some motoring.
Bob in Ga is offline   Reply With Quote
Old 01-22-2014, 05:42 PM   #62
RobertB
RobertB's Avatar
Someone help a newbie that doesn't know the differences in A and B engines, and loves the sound of "more power"...araghhhh.
RobertB
Santa Teresa, NM
RobertB is offline   Reply With Quote
Old 01-22-2014, 06:00 PM   #63
Tiny
Tiny's Avatar
A engines were used in the Model A from 28-31. They are gravity fed
B engines came in 32-34 Models they have a fuel pump and many "improvements" that make them rated at 50 hp not 40hp like the A. There are lots of differences between them I'm just giving you the Cliff Notes. The search button and Google are your friend if you are interested in a more detailed answer.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 01-22-2014, 06:07 PM   #64
Bob C
Follow the link to Vince's site then scroll down to ENGINE.
http://www.fordgarage.com/
Bob
Old 01-23-2014, 01:47 AM   #65
Manuel
Good to see the B Group running again.
Manuel in Oz
Manuel is offline   Reply With Quote
Old 01-26-2014, 12:34 PM   #66
jim1932
jim1932's Avatar
I'm in! looking for more stock and low key builds rather than the way out hotrod motors on the Bangers threads on HAMB.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 01-26-2014, 05:54 PM   #67
skryla
skryla's Avatar
I'm working on my 31 deluxe roadster with a B engine.
skryla is offline   Reply With Quote
Old 01-26-2014, 09:47 PM   #68
Randall
Randall's Avatar
I"m in
Randall is offline   Reply With Quote
Old 01-27-2014, 05:49 AM   #69
32forddump
32forddump's Avatar
I would like to join as well. I have a BB dump truck and building a 28 roadster with a B engine and tranny. Is it difficult to drop a b engine and tranny in a model a frame?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 01-27-2014, 11:10 AM   #70
Tiny
Tiny's Avatar
I like that homemade up/down draft intake.
Blackwall Panthers
Nor Cal chapter
Old 01-27-2014, 03:45 PM   #71
skryla
skryla's Avatar
I'm not sure if I'm going to use it. This engine was assembled in the late 50's and never run. I bought it from a guy who recently acquired it, took it to a machine shop had it disassembled, tolerances checked reassembled and run.
Old 01-27-2014, 03:53 PM   #72
Tiny
Tiny's Avatar
Let me know if you don't. I'm always on the look out for homemade hop up parts. That motor has some really neat details on the outside. Whats on the inside?
Blackwall Panthers
Nor Cal chapter
Old 01-28-2014, 08:15 AM   #73
32forddump
32forddump's Avatar
All those fuel pumps gone?
Old 01-28-2014, 05:43 PM   #74
jerseyboy
jerseyboy's Avatar
skryla,
Can I stop by while I'm down around exit 83?
Keep 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 01-28-2014, 06:44 PM   #75
skryla
skryla's Avatar
Originally Posted by jerseyboy View Post
skryla,
Keep 4-banging!
Sure Jersey Boy. I am exit 89. I will be working on setting the 32 front end in the 31 this weekend. Parts are growing all over the garage!
Old 01-29-2014, 01:28 AM   #76
marcshall
i have a B motor with a BB crank , light flywheel v8 cluch 32 transmission ,mitchell gear splitter ,down draft 1 bbl glass bowl holly carb .in a 30 sedan. been runing it for 7 year now . got a few B blocks a few have been welded up i welded 1 up at the back by the firewall, could not believe how thin it was . i think the castings are thiner then the A blocks
marcshall is offline   Reply With Quote
Old 02-03-2014, 08:32 PM   #77
skryla
skryla's Avatar
I had some success over the weekend. Got the 32 axle under the 31 roadster. Once I get the brakes, drums and tires on, it will be time to put the B in.
Old 02-03-2014, 08:41 PM   #78
quickchange
quickchange's Avatar
So who has a good crack free diamond B block to sell for a new salt engine , Needs to be in CA,, AZ , area, only need a block & one i can afford. mail me direct , Thanks,
quickchange is offline   Reply With Quote
Old 02-10-2014, 07:51 PM   #79
Bob Bidonde
Bob Bidonde's Avatar
I have Model "B" engines in my Coupe and Victoria, so I am enthusiastic about this forum.
Bob Bidonde
Old 04-13-2014, 11:40 AM   #80
Gabalus
I have a Model B engine on my 1928 model a Phaeton.
Gabalus is offline   Reply With Quote
