Old 01-21-2014, 12:15 PM   #41
Charlie Stephens
Default Re: 1932-34 Model B Four Cylinder Group started!
Originally Posted by MN Stumpjumper View Post
This thread was started in 2010. I just went to the groups pages and did not find a B group. I may have been removed.
I had the same problem. If anyone can find it I would appreciate help.
Charlie Stephens
Old 01-21-2014, 12:45 PM   #42
machine girl
how do we join!!!!
machine girl is offline   Reply With Quote
Old 01-21-2014, 01:10 PM   #43
jerseyboy
jerseyboy's Avatar
If I recall correctly, Vince left the barn due to "hard to deal with Barners". So the B Group was discontinued.
Keep 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 01-21-2014, 01:36 PM   #44
hardtimes
hardtimes's Avatar
Yup, you recall correctly, from my memory. Sadly, Vince is not the only great talent/contributor who was 'put off' by the petty BS from some. Hope they reconsider, because they helped others, maybe without their even knowing.
Old 01-21-2014, 01:57 PM   #45
machine girl
That's to bad wish ryan would open up a site for us model a-b modifieds. the hamb is good but to universal. would be nice to specialize. I bet it would be a big hit!
Old 01-21-2014, 02:00 PM   #46
Mike V. Florida
Mike V. Florida's Avatar
Vince is back and hopefully he will read this.
Old 01-21-2014, 03:36 PM   #47
juke joint johnny
juke joint johnny's Avatar
He put in a lot of work on his Ford Garage site!!!
A big help to lot's of people including me.
John Cochran
juke joint johnny is offline   Reply With Quote
Old 01-21-2014, 04:17 PM   #48
a&tlover
I have A 34 B motor in my 31 160b the motor was rebuilt by Ron Miller
a&tlover is offline   Reply With Quote
Old 01-21-2014, 04:25 PM   #49
quickchange
quickchange's Avatar
Lets keep this thread going & maybe something will happen, Just purchased some new inserted rods, as running full presure, & inserts have holes in them now pluggiong top & bottom holes, taking the dipper off too, Derek
quickchange is offline   Reply With Quote
Old 01-21-2014, 04:55 PM   #50
Juggler
Juggler's Avatar
I'm in
Juggler is offline   Reply With Quote
Old 01-21-2014, 05:45 PM   #51
G Baese
G Baese's Avatar
Subscribed!
G Baese is offline   Reply With Quote
Old 01-21-2014, 06:27 PM   #52
Mike V. Florida
Why don't one of you that have such a car start it again?
Old 01-21-2014, 07:00 PM   #53
machine girl
YES!!!B motors, insert bearings ,downdraft carbs,overdrive transmissions, alternators, hot cams, the fun would never end!
Old 01-22-2014, 11:18 AM   #54
Bruce Lancaster
The HAMB can be hard to deal with because it is so big and diverse, but the A-B folks have done a pretty good job of centralizing much of the information: There is a Monthly thread started every month that cumulates much of each month's discussion and provides links for other good 4 cylinder material. Once you lock into that series of threads life becomes easier...here's the January 2014 one, which contains at the top quite a few archive worthy links:
http://www.jalopyjournal.com/forum/s...monthly+banger
Model B stuff always needs a bit of looking, as the engines are considered orphans by both the Model A and the V8 people...no momma, no poppa, no uncle Henry.
Old 01-22-2014, 12:43 PM   #55
Mike V. Florida
OK it's re-started as a public group
Just remember it has the same rules as the rest of Fordbarn.
Have fun
Old 01-22-2014, 01:19 PM   #56
Tiny
Tiny's Avatar
I'm in!!
Mike I just joined. Do I get a free puppy?
Although I only have a lowly A motor, hope that's OK?
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 01-22-2014, 01:23 PM   #57
quickchange
Mike , thanks , think i just joined by following the instructions , Anyone have flow tests & how large a dia intake valves one can fit with out breaking into water jackets ? Just picked up a sacrifice block where a machine shop just cut through each valve hole to fit seats, went so large they got into water jackets then tried to braize each hole up , what a mess ,stuffed a good block , We may slice it to get an inside picture of the casting. Hot in NZ
Old 01-22-2014, 04:16 PM   #58
machine girl
What is the link to get on board ?
Old 01-22-2014, 04:33 PM   #59
Juggler
Juggler's Avatar
See if this works...
http://www.fordbarn.com/forum/group.php?groupid=80
Old 01-22-2014, 04:43 PM   #60
machine girl
that worked!!!
