First make sure you are signed in.
Click on the Quick Links in the black band then in the drop down select "Edit Your Details" when the new page opens go over to left to the "Your Control Panel" column and open "Edit Avatar" Adding an avatar does not make you a senior member, it's how many post you have made. Hope that helps. Last edited by redmodelt; 01-17-2014 at 07:57 PM. Reason: changed right for left |
