ive dissembled my Model A engine. sad to fine it in worse shape than i thought i would fine. here are a few pics of the rear bearing area. whats your opinion on what is my best repair options now?
it appears as tho the Babbitt is coming apart . how many miles ? if the rear is like that , what does the center look like ? I think rebuilding is next ........
V4f |
What was the reason for taking the engine apart?
Was it just to check things out, or was there a specific problem? |
just checking things out i have never had the engine running. i was hoping to dissemble and clean and reassemble but now im not sure what to do.
I see you still have some shims in the rear bearing. IMO: If you are just going to drive it a few times each summer, you could probably put it back together adjusting the clearances as you do and it would likely last a couple to many years if you keep the RPM's down. I suggest you study the rest of the components to see if they are worthy of reassembly or need attention. (As commented above...what condition is the center main in?)
Good Day! Last edited by Dave in MN; 01-25-2014 at 08:36 PM. |
Mark in MTAlways looking for another opportunity to be wrong. |
Maybe I'm missing something, but, I'm with Dave.
ok im feeling a little better now. i was thinking i was headed for $$$$ with no other options. the center main bearings are much better than the rear bearing.yes i will only be driving limited amouts
I also agree with Dave. Chances are the babbit in my temporary Phaeton engine looks worse than your's, and I'm still driving it.
#10 | |
http://www.model-a-ford-4bangers.com/ |
Im not an expert by any means. I had a similar thread a few weeks ago. The babbit on the rear main was cracked like yours except it was on the cap...and it was missing the oil drain tube, so i had a severe oil leak AND damaged babbit....scared the crap out of me. I took the advice of James and adjusted the clearance on the mains using the foil method and put it back together. So far so good, and no oil leak.
#12 | |
Here is the link. http://www.fordbarn.com/forum/showthread.php?t=126563 Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
#13 |
After refurbishing two marginal engines and driving them for years (a couple thousand miles) I can also say that if you can get the proper clearance, you are probably OK. This is especially true if you're not planning on any long distance interstate tours.
My patch together engines have actually laster longer than one that I had "professionally" rebuilt. |
