Old 09-15-2010, 01:52 PM   #7
Commander Toasty
Send a message via ICQ to Commander Toasty
Default Re: Jumping out of 2nd gear
(Check that the two metal spacers are inserted in the two ears of the clutch housing where it attaches to the engine block. The spacers are brass and are .010 thick. Their purpose it to properly align the housing to the drive line of the car. They should be the same thickness as the gasket installed between the housing and the block. If they are missing they can be easily installed. Bratton has them in their catalog.)
Do you have a picture or diagram of this location?
Commander Toasty is offline   Reply With Quote
