Old 10-20-2013, 11:08 AM   #10
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Weak #6 cylinder
It's time to push out the pistons, it looks like the lower cyl in the picture that the top compression ring is broken---the cyl by the blue dipstick shows a good shadow that is even all around(as much as the picture shows), the bottom cyl shows ring contact in just little streaks ---most likely from the ends of broken ring pieces ---if that is also the low compression cyl most likely that is a factor in the low compression
