Old 08-08-2013, 02:03 PM   #1
Ken Bull
Ken Bull's Avatar
Default Ignition switch failure
Took my 36 Cabriolet for a excersize drive today Stopped at a friends shop for a few minutes & no start After some diag. found the Ing switch not working so jumped to get home & replace switch This was the 1st time this part was an issue for me. Any Tips?
Ken Bull is offline   Reply With Quote
Old 08-08-2013, 03:05 PM   #2
Gary Duff
Default Re: Ignition switch failure
Ken----Replace with NOS Ford switch plate and brush. Fits 32 thru 37.
The remakes are warped junk. I just fixed a 37 that failed on the way home from Tahoe meet. Check the resistance when you are done installing new parts, before you connect wires. Should be .1 ohm or less.
Gary
Gary Duff is offline   Reply With Quote
Old 08-08-2013, 03:31 PM   #3
NormC
NormC's Avatar
I had the same issue in my 36 pickup.
Clean the contact on the plate and adjust the brush to increase the spring pressure.
Norm
NormC is offline   Reply With Quote
Old 08-08-2013, 06:05 PM   #4
bluardun
bluardun's Avatar
I too had an issue with the brass "brush". It is a moving part that is 75 years old. Has to wear out. The origional ones are getting hard to find. Thanks to a gentleman here on the Barn, I was able to replace mine with a NOS brush.
bluardun is offline   Reply With Quote
Old 08-08-2013, 06:29 PM   #5
russcc
Stacy, Arlington TX has NOS. 817 275 2381
Old 08-08-2013, 06:41 PM   #6
Clem Clement
Clem Clement's Avatar
I loosened the screws on mine and it recovered. We found that on another switch I have, if the screws are too tight it warps the case.
Old 08-08-2013, 11:02 PM   #7
Gary Tosel
Gary Tosel's Avatar
I realize that the manufacturers of replacement parts list the ignition switch as 32-37, but in 37 they reversed the "on" direction from down (32-36) to up for 37 so the switch would not work the same.
Gary Tosel is offline   Reply With Quote
Old 08-09-2013, 04:32 AM   #8
mike42
mike42's Avatar
Bull.....
I had a similar problem with my '40 switch. I bought two from Mac's and neither of them worked so I sent them both back. I bought one from C & G.....and it worked. I also noticed that is was manufactured better. I have no way of knowing if it was made by another company or not, but bang....it worked immediately after putting it in.
Mike
mike42 is offline   Reply With Quote
Old 08-09-2013, 12:46 PM   #9
Ken Bull
Ken Bull's Avatar
I took it apart, cleaned the contacts, bent the brush a little at each end put together & works good. Will keep a jumper wire in glove compartment for insurance. Thanks all for the tips
Old 08-24-2013, 12:28 AM   #10
Obsolete Jim
Obsolete Jim's Avatar
Actually Ford made the On-Off position change in Late '36.
Obsolete Jim
Obsolete Jim is offline   Reply With Quote
Old 08-24-2013, 08:12 AM   #11
G.M.
Ken and Norm, you got it. You should take the little rounded contacts and run them over 1000 sand paper on a flat surface. This will give you little flats on the bottom for better contact area. I have never seen a seen a relay with round contact surfaces. Also sand the wear and arc marks out of the flat contact plate and finish with 800 or 1000 paper again on a flat plate. The original plates were milled with a fly cutter or shaper and had big ridges and groves, along with the round contacts this is what started the arcing. G.M.
www.fordcollector.com
Old 06-12-2017, 12:32 PM   #12
Artiki
Artiki's Avatar
Cheers guys. Bringing this back from the archives with a thank you. Had the same issue with a '38 I've just bought and it was the contacts in the switch. Used G.M.'s methods of flatting them with 1000 grit lubed with Plusgas, and all is good.
Artiki is offline   Reply With Quote
Old 06-12-2017, 08:23 PM   #13
Karl Wolf
Karl Wolf's Avatar
If you're running a bunch of electrics, it's possible to use a relay. The ignition switch would only have to run power to operate the relay. I have a bunch of Bosch 40 amp relays from old car projects- that's what I use.
I put them into the headlight circuits of my old Ford pick up as the head lamps I used would use amperage that would melt the dimmer switch.
Karl
Karl Wolf is offline   Reply With Quote
