Old 07-28-2013, 09:38 AM   #1
wi0v
wi0v's Avatar
Default Engine Color
Looking for the correct engine color for a 56 Merc 312. There must be someone out there than has an original car.
Gary
wi0v is offline   Reply With Quote
Old 07-28-2013, 05:48 PM   #2
Ole Don
Ole Don's Avatar
Default Re: Engine Color
I had a 56 Merc 312 in a hot rod in 1959. I have a 312 now in my 55. The best I can do is called "Universal Gold", its a high heat engine enamel in a rattle can. Used on many Oldsmobile and Mercs. I get the assembled engine on a stand, wipe it down with a rag soaked in acetone. Prime the sheet metal with a light coat of red oxide, then coat it all with four light coats of the gold. I have found nothing that will cover and stay on the exhaust manifoild's for more than a few months.
Ole Don is offline   Reply With Quote
Old 07-28-2013, 07:35 PM   #3
raceron1120
raceron1120's Avatar
I have seen both yellow and gold in the '56s. Mine is gold, very close to the original color it was when I got it. It's a '55 Mercury 292 engine.
raceron1120 is offline   Reply With Quote
Old 07-29-2013, 08:09 AM   #4
wi0v
wi0v's Avatar
Thanks for the information, I've seen some gold on line but also every color in the book. So gold it will be, now how about valve covers?
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
Old 07-29-2013, 08:33 AM   #5
Ole Don
Ole Don's Avatar
My 56 rocker covers and air cleaner were orange. My current rockers are white like Raceron has. It looks very good when you open the hood at cruise night. The chrome aftermarket covers are OK, but wax them well inside and out to keep the chrome from peeling.
Old 07-29-2013, 04:58 PM   #6
wi0v
wi0v's Avatar
Don: I like the white but if there is no standard maybe I'll go with the yellow to match the cars original color. However, still would like to find the original color. I'm kind of that way, goes back to my Model A restoring days.
Gary
Gary Danford
Chadron, Nebraska
816-258-2300
[email protected]
Old 07-29-2013, 07:21 PM   #7
Blue Futura
Blue Futura's Avatar
I was a teenager when the 56 Merc came out and a uncle of mine bought a new one. I remember noticing the engine was yellow not the same as my dads 55 ford.
64 Futura , bought new.
56 ford fairlane , bought about 30 years ago.
35 chevy street rod , started building in 2000.
Blue Futura is offline   Reply With Quote
Old 07-29-2013, 08:01 PM   #8
Daves55Sedan
Daves55Sedan's Avatar
Don, back in 1984, I coated my freshly sandblasted exhaust manifolds with a ceramic coating called "HOT STUFF". I purchased it from JC Whitney & Co. It comes in a small plastic container. You paint the maniofolds using a artists paint brush. Now all these years later, there is barely a blemish in them and my engine has turned over a few times since then.
Theres one catch. You must get the manifolds very hot immediately after painting them to "cure" the coating on the cast iron. If you don't do that, the ceramic will flake off prematurely.
Don't know if they still sell it, but its worth looking into.
Old 07-30-2013, 05:20 PM   #9
raceron1120
Actually, the valve covers kind of an off white, maybe antique white? I can't remember what it is called but it was a very close match to others I've seen.
Here are a few pictures I found online - except the last one is of my engine when I got it:
