Old 07-23-2013, 11:03 PM   #1
Junior
Junior's Avatar
Default Where should I mount this?
I am about finished installing a turn signal kit. Front lights, back lights, and back window brake light/signals have been wired in.
I get to this huge flasher thingamagig and I can't decide where to mount this big silver monstrosity and not creating a ugly mess. The only place I can come up with is the steering column, but I really don't want it there.
Any ideas? Where do you guys mount the signal flasher?
Learning the A at the Ford Barn, so I can pass it down do the next generation.
Junior is offline   Reply With Quote
Old 07-24-2013, 12:39 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Where should I mount this?
Steering column, PERIOD!!! Would you want to be fumbling around somewhere tryin' to find it???
Folks will say, "OH! you a SMART MAN to have added signal lights"!!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-24-2013, 01:13 AM   #3
CarlG
CarlG's Avatar
When you get it mounted on your steering column, you will grow to like it there. It's not all that obtrusive and it looks period correct.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-24-2013, 05:52 AM   #4
MikeK
MikeK's Avatar
I've seen some mounted fairly low on the column, way down by the gas tank. Personally I like mine high enough so it can easily be reached by fingers with my thumb still hooked on the wheel.
MikeK is offline   Reply With Quote
Old 07-24-2013, 06:02 AM   #5
waxhead
waxhead's Avatar
Are you not talking about the silver flasher, rather than the indicator switch?? it appears to me like everyone has answered where to locate the indicator stalk/switch. I am yet to mount mine, so interested to see what people suggest.
waxhead is offline   Reply With Quote
Old 07-24-2013, 06:10 AM   #6
Junior
Junior's Avatar
Yes, it's the Silver Round Flasher that I am referring to. I confused folks by posting the pic of the whole kit. Sorry. I mounted the switch (arm) right below the sparky arm.
Old 07-24-2013, 06:16 AM   #7
roccaas
roccaas's Avatar
My control is just below the wheel at 9:30 o:clock.
I wrapped the wires with the dull black plastic cable shielding available at auto parts stores and have the flasher just above the floorboard, zip tied to the steering column.
Be careful not to kick it as you'll lose your flashers. I thought about mounting it below the floorboard, but I was concerned with chafing the wires.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 07-24-2013, 06:20 AM   #8
Mike in NRN IN
Mike in NRN IN's Avatar
I purchased woven wire loom and fed all the wires through the cloth loom.
I used the A Style connectors and bullets to create disconnect points between the inside and outside.
Then mounted the relay/flasher using an existing hole in my firewall. The holes were pretty high up in the cab, so the flasher is only visible if you climb around and look for it.
The advantage, I plugged two holes in the firewall, the wires were contained in a period looking loom, and I can easily disconnect/reconnect the switch if/when necessary.
I have seen the flasher mounted behind the panel in the cab area. It looks nice, but you have to remove the panel to replace the flasher unit.
Mike in NRN IN is offline   Reply With Quote
Old 07-24-2013, 06:38 AM   #9
Keith True
Keith True's Avatar
I have one mounted above the kick panel.That is on a 30,I would have to look to see how it would go there on a 28-29.I actually have my signal switch mounted there too.It is mounted fore and aft,to the cowl brace,handle sticking out toward the rear.Up is right and down is left.You can't even see it unless you are looking for it.
Old 07-24-2013, 07:25 AM   #10
[email protected]
modela@aol.com's Avatar
If you are using 6 volt LED tail lights you can also use a solid state electronic 6 volt flasher. They are out there on EBay and other sources as they are used on the older Japanese 6 volt motorcycles. They give a very good rate of dependable flash that is always repeatable.
When using LED lights the old bi-metal flashers don't always get enough current draw to flash the lights properly. The flasher units that say Heavy Duty are the worse ones for LED lights as they were actually designed for use with vehicles pulling trailers that added more extra lights to the flasher circuit calling for even more current draw to make the flasher work correctly. The original 6 volt flasher cans that do not say Heavy Duty on them often work fine with LED lights and also give the original style bulbs the best flashing...
modela@aol.com is offline   Reply With Quote
Old 07-24-2013, 03:28 PM   #11
Jason in TX
Jason in TX's Avatar
Mount it in the engine compartment. Lengthen the wires if you need to.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 07-24-2013, 06:33 PM   #12
1931 flamingo
1931 flamingo's Avatar
I mounted a buss bar attached with magnet to the cowl BEHIND the driver's kick panel and the flasher's there also. All wires covered in the original style loom. Stalk is on the strg column.
Paul in CT
Old 07-24-2013, 06:34 PM   #13
Junior
Junior's Avatar
Think I will paint it black and hide it in the engine compartment some where.
Thanks to all for suggestions and ideas..
Old 07-24-2013, 10:41 PM   #14
quickchange
quickchange's Avatar
I use the middle bolt of the engine pans by making a loop strap from piece of tin, Its sits inside the frame where the wires from switch run, Front hole has the horn reducer mounted there too , Out of site & protected,
quickchange is offline   Reply With Quote
Old 07-24-2013, 10:50 PM   #15
Logan
Logan's Avatar
Just put it behind the drivers side cowl kick panel
Cowtown A's
Logan is offline   Reply With Quote
Old 07-25-2013, 06:48 AM   #16
Arlen
Arlen's Avatar
I'm like Logan. Put it behind the drivers kick panel. You want it close enough you can hear it clicking.
DMAFC
Arlen is offline   Reply With Quote
Old 07-25-2013, 07:55 AM   #17
Dave in Boise
Dave in Boise's Avatar
I mounted mine on the drivers side of the coil by lengthening the wires and using a 1" single leg conduit clamp painted black from the firewall mount screw for the coil. Easy to get to if you want to change it out, and unless looking for it, might be mistaken for a part of the ignition system
Dave in Boise is offline   Reply With Quote
Old 07-25-2013, 09:08 AM   #18
whirnot
whirnot's Avatar
Mine is in the engine compartment, bolted to the sheetmetal just above the left motor mount. It is mounted to the back side, so it is invisible but easilay accessed if needed.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 07-25-2013, 09:19 AM   #19
Keith True
Keith True's Avatar
If you're using the flasher in the picture you need to have easy access.They don't seem to last at all.I thought I must have had a short that would come and go,something like a chafed wire.A new flasher would last a month,or sometimes a year.The old one I took out of a Studebaker works fine.Then I put one of the new ones in the Studebaker,it heats up,clicks fast,then slow,and stops sometimes.I did find one that seems to be behaving,but if I sit at a stoplight too long it will start to speed up.
Old 07-25-2013, 10:26 AM   #20
jrelliott
jrelliott's Avatar
Put it behind the drivers side kick panel. If loud enough will hear the clicking which will tell you still have the signal on after a turn as these are not self cancelling like ones on later vehicles. Another suggestion is to make all the connections to the indicator stalk switch and the other wires through a multi pin connector available at Radio shack so you can trouble shoot easily if something does not work. Makes taking out easy
