Old 07-15-2013, 05:34 PM   #13
Bruce Compton, Canada
Default Re: 16" wheels on my '28?
If you are attempting to do really accurate calculations, you should use "loaded radius" and not diameter. Measure the loaded radius from the centre of the wheel/hubcap to the ground after checking inflation pressure and with the weight of the car on the wheel. Cheers : Bruce
Bruce Compton, Canada is offline   Reply With Quote
