Old 06-16-2013, 12:28 PM   #1
Coreyfatboy
Coreyfatboy's Avatar
Default Leaky steering box
I have a 36 ford pick up and thought I had a bad oil leak and when I put it on my lift found it to be the steering box. Is this a hard fix. Thanks
Coreyfatboy is offline   Reply With Quote
Old 06-16-2013, 12:48 PM   #2
woodypecker
woodypecker's Avatar
Default Re: Leaky steering box
new grease might make it a lot better
woodypecker is offline   Reply With Quote
Old 06-16-2013, 12:51 PM   #3
trainguy
trainguy's Avatar
Depends where it is leaking from.There is a bottom plate where the light switch clips on.This plate is scewed to the box with 2,1/4 screws.The plate has a tube swedged to it which extends up inside the steering box.This tube often is loose or broken causing a leak into the light switch.You can buy this plate or repair yours.There is a gasket between the plate and the box.The other comon leak is caused by worn steering shaft bushings/shaft,which should be repaired.A thicker gear oil that can be obtained from restoration supply in Ca. will slow down the leak.
trainguy is offline   Reply With Quote
Old 06-16-2013, 01:07 PM   #4
G.M.
Low temp grease works good. It's right next to the exhaust manifold so it don't
make the steering hard. G.M.
www.fordcollector.com
Old 06-16-2013, 02:31 PM   #5
Coreyfatboy
I've noticed about an 1/8 to 1/4 turn of play in steering wheel. Box is probably shot. Rebuild or replace?
Old 06-16-2013, 03:50 PM   #6
Lawson Cox
Lawson Cox's Avatar
The play you find in the steering wheel generally indicates worn tie rod ends, or worn gears. Lay under the truck and have someone turn the wheel in both directions while you look for play in the tie rod. When any play in the tie rod ends is taken care of, you might be able to adjust the steering gear itself. Try all that before tearing the steering box out and taking it apart.
Old 06-16-2013, 03:54 PM   #7
Bassman/NZ
Bassman/NZ's Avatar
I had a leaky box, put Penrite Steering Lube in, and it hasn't leaked a single drop since.
Bassman/NZ is offline   Reply With Quote
Old 06-16-2013, 07:16 PM   #8
1931 flamingo
1931 flamingo's Avatar
Penn-Rite steering box lube is the easy way out. Available from Restoration Specialties, Escondido, CA. They have a web site, about $15 + shipping.
Paul in CT
Old 06-16-2013, 07:20 PM   #9
trainguy
trainguy's Avatar
This is the stearing box lube from Restoration supply in calif.Good stuff. Phil
Old 06-16-2013, 07:32 PM   #10
Talkwrench
Talkwrench's Avatar
I used Lucas heavy duty oil stabilizer, its ok . maybe try the Penrite stuff and see how you go. There are very fine gaskets on that end plate so be careful if you pull it away.
Old 06-16-2013, 11:33 PM   #11
Brendan
Brendan's Avatar
that is where my steering box leaks from, I figure it keeps the light switch lubed up...LOL
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 06-17-2013, 02:13 AM   #12
flatheadfan
flatheadfan's Avatar
Coreyfatboy-
Replace!! "35-'36 boxes are notorious for leaking even under the best of circumstances. Do yourself a HUGE favor and install a '37-'39 steering gear box. Granted, it involves some work but the end result is a better box (feels like power steering), easy to adjust and greatly reduces the tendency to leak. Go for it!
Tom
flatheadfan is offline   Reply With Quote
Old 06-17-2013, 09:54 AM   #13
Coreyfatboy
What work is required to switch the box to a newer one
Old 06-17-2013, 10:05 AM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
The original steering box on my 35 fordor sedan leaks bad when I use gear oil. Just before leaving home for the cross country tour I filled the box with JD Corn Head Grease. No leakage in the last 3,000 miles. I really don't want to change to the later box with rolling sector on an original Rouge class car. It steers fine with original steering gear.
John
Old 06-20-2013, 07:52 AM   #15
JLB3
+1 for the John Deere corn head grease. Its made for "fill for life" gear applications and works well in steering boxes. Much thinner than typical grease.
JLB3 is offline   Reply With Quote
Old 06-20-2013, 12:15 PM   #16
peewee2you
peewee2you's Avatar
Just as an FYI, the above company out of Escondido, CA is called Restoration Supply Company, not specialties, in case you were looking for it and going to go that route
1200w lube at $15. I was trying to find it under that name and didn't just trying to help out, thanks to Paul in CT., I did not know about this company.
peewee2you is offline   Reply With Quote
Old 06-20-2013, 12:59 PM   #17
1931 flamingo
peewee: specialties/supply, glad you found them. It works.
Paul in CT
Old 06-21-2013, 11:08 AM   #18
blucar
blucar's Avatar
I converted my '36 to a '40 steering box in 1955, what a difference, like adding power steering to the car.. Especially when trying to park.
I have used Motor Honey, STP, etc., in old car steering gears.. Works great.. Leave it sit in the sun for awhile, put a small funnel into the gear box and slowly pore the oil in..
The Motor Honey/STP is very sticky, does a good job of adhering to gears, shafts, etc..
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 06-21-2013, 12:07 PM   #19
rotorwrench
rotorwrench's Avatar
The Gemmer I type steering box designs aren't as good as the 37 on Gemmer II design with the rolling sector gear but they will work if you just want to drive the truck occasionally. The only place the sector & pitman will have little or no play is if the box is centered for driving straight down the road. It should be checked with the front wheels off the ground & centered. The play is ajustable to a certain degree. If the worm has excessive wear or galling pits in its gear surface, then it will have a notchy feel to it and will require replacement.
Old 06-21-2013, 07:57 PM   #20
Henryat1140
Henryat1140's Avatar
Charlie NY (Charlie Schwendler) did an excellent job of rebuilding a 37 box for us.
He always goes the extra mile. Highly recommended.
Henryat1140 is offline   Reply With Quote
