Old 05-28-2013, 03:17 PM   #1
CaliforniaBorn36
CaliforniaBorn36's Avatar
Default 1936 Horn problem
I know there was a lengthy thread here recently about a problem like this but it was for a 1941, and looking at the Wiring diagrams on Vanpelts site it seems the 1936 is a bit different. Looks like the 1936 does not have a horn relay. Is that correct?
My symptoms are:
1. Hit the button I can hear the horns click but not sound
2. Hook the blue and yellow wire to ground, the horn blasts quite loud.
So I am assuming the horn button completes the ground and if I want to put in an auxillary button under the dash, it is grounded, not wired to power, is that correct? And run to the blue/yellow lead.
If the switch is to ground, does the line need to be fused? If so, what size fuse is appropriate?
Thanks for any guidance.
CaliforniaBorn36 is offline   Reply With Quote
