Old 04-15-2013, 09:37 AM   #21
Jim Mason
Jim Mason's Avatar
Default Re: Shocks: Necessity or luxury?
they prevent the rocking chair ride, darting while driving (especially on rough roads), darting while brakeing, front axle pendelum, and body roll. It's like flossing. You only have to floss the teeth you want to keep.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is online now   Reply With Quote
Old 04-15-2013, 09:51 AM   #22
luckyal
You take the chasnce of seriously injuring yourself, your passenger and the person you hit when the car swerves ! The expensive set is a major investment but well worth it !
Al
luckyal is offline   Reply With Quote
Old 04-15-2013, 10:13 AM   #23
Fred
Originally Posted by jkeesey View Post
Rebuilt originals do work nice but they are definitely not cheap. Shocks in my opinion are mandatory, running without them can cause some serious issues.
A lot cheaper than $1,000 + for a re-pop set..
Fred is offline   Reply With Quote
Old 04-15-2013, 10:14 AM   #24
Gord. B by the bay
In Canada you cannot get an ownership with a plate with out in inspection and one it em is shocks Gord, B
Gord. B by the bay is offline   Reply With Quote
Old 04-15-2013, 10:25 AM   #25
TudooR31
TudooR31's Avatar
I too recommend Ron Paul. I added the missing shocks on my tudoor and it made a big difference in ride and control. Your '29 coupe sounds like a very nice car. Why leave out a major part of the suspension?
TudooR31 is offline   Reply With Quote
Old 04-15-2013, 10:38 AM   #26
MikeK
MikeK's Avatar
If you're trying to find/match an older 'modern' shock, here is a catalog of Mounting and Length Specifications from Monroe. LINK It is also quite useful for custom buildups.
MikeK is offline   Reply With Quote
Old 04-15-2013, 10:41 AM   #27
Fred K-OR
Fred K-OR's Avatar
Mike, welcome fellow Oregonian!
I have shocks on both of my rigs. When I first finished the huckster, I did not have shocks on it. So I went cheap and purchased a new aftermarket set from M&S. They are located in Hillsboro, OR. I think they are still around $500. Before getting them on my huckster being it is a heavy rig, it handles much better with them. I am not an expert on shocks, but the M&S shocks seem to work fine for me on the huckster. But I do not drive the rig more than 45 or 50 MPH and it is all stock, no two speed setup and they seem to give it stability for me. I also do not take the huckster on long cruises. So it is a parade car and a grandkid hauler around local. So guess my point is that the need for them is well expressed above and if they are not needed, Ford would not have put them on in the first place.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-15-2013, 10:53 AM   #28
barnstuf
I am in favor of shocks and would like to point out a no shock happening no one has mentioned yet. If driving with no shocks and you hit a pot hole or go over a railroad track the spring leafs all absorb the shock as the car bottoms out, but on the rebound only the main leaf is picking up the front end or rear end and carrying most of the load. It is not unusual to have the spring main leaf broken and this is often the cause.
barnstuf is offline   Reply With Quote
Old 04-15-2013, 10:54 AM   #29
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
The stability of your A when going about 45mph through a sweeping turn is greatly enhanced with a set of working shocks. Without good shocks at 45mph in a sweeping turn the banjo tends to skip sideways accross rough pavement. Call shock rebuilder John Holland (330-483-3896) for a set of reasonably priced rebuilt shocks. He rebuilt mine and I am totally satisified.
Dick M is offline   Reply With Quote
Old 04-15-2013, 12:46 PM   #30
Rock Hornbuckle
Rock Hornbuckle's Avatar
Shocks are definately a must have item. It's your choice as to what kind, but PUT THEM ON FOR SAFETY !
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 04-16-2013, 12:02 PM   #31
29er
29er's Avatar
Smile Re: Shocks: Necessity or luxury?
Thanks guys! Lots of wisdom among you all. This is gonna be fun! Your replies stimulated some research on my part.
Seems shocks ARE necessary (mandatory as one of you said) for: (1) safety; (2) protection of springs, frame and maybe even tires; and (3) comfort. 'Ol Bill W's photo of the toppled "A" should convince everybody (but Bill, did ya notice several of those jars of moonshine were unbroken!).
Anyway, I made a few calls yesterday to see what's available. Thought I'd share what I discovered. Seems current options for shocks are: (1) modern tubular types; (2) rebuilt originals; (3) new "sealed" Houdaille reproductions; and (4) Bill Stipe's remanufactured/ retooled Houdaille-type. Other threads at FB adequately discuss these.
Several people told me the originals are getting harder and harder to find, especially those that are still in suitable condition for rebuilding. Bert's told me they don't have anymore to rebuild unless you supply them. The guys who rebuild them are listed in Pluck's list and on other threads here at FB.
Fortunately, I've got 4 in the barn and will likely rebuild them for the learning experience.
Thanks again for your thoughts. I'll look forward to being part of the Model A Forum.
Mike
29er is offline   Reply With Quote
Old 04-16-2013, 12:40 PM   #32
Fred K-OR
Fred K-OR's Avatar
BTW Mike, what part of Oregon are you from?
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 04-16-2013, 12:44 PM   #33
Bruce Adams
Bruce Adams's Avatar
I found out years ago that having shocks makes the difference between driving a BABY BUGGY and driving a car. I can not imagine driving without shocks.
Bruce Adams is offline   Reply With Quote
Old 04-16-2013, 01:25 PM   #34
bill44
bill44's Avatar
I put modern shocks all the way around. The front was too stiff and I cannnot find a oil filled replacement. I took off the fronts and just have the rears on. The car rides well and I don't have any control problems.
bill44 is offline   Reply With Quote
Old 04-16-2013, 06:30 PM   #35
sconnors
sconnors's Avatar
Saw these in the Snyder's catalog, and I need some on the front of my pickup because I only have them on the rear. Are these worth it???
http://www.snydersantiqueauto.com/5684
sconnors is offline   Reply With Quote
Old 04-16-2013, 07:16 PM   #36
roccaas
roccaas's Avatar
Henry thought they were a necessity!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 04-17-2013, 08:58 AM   #37
Elcastor
Elcastor's Avatar
Stay away from having M&S rebuilding your originals. I had nothing but leaking shocks after having mine done there. I even took some of them back to be redone, and they still leaked. No problems with Rob Paul rebuilds.
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 04-17-2013, 09:25 AM   #38
sconnors
sconnors's Avatar
Just saw in the 2013 Snyder's catalog they have stopped selling these due to "quality issues"
Old 04-17-2013, 10:33 AM   #39
gwhite
gwhite's Avatar
What should I look for when trying to find 'rebuildable' shocks?
gwhite is offline   Reply With Quote
Old 04-17-2013, 10:41 AM   #40
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the fill plug and if powdered rust falls out, it's only good for a paper weight.
Also if the square shaft too much side clearance they are too worn for use.
