Old 04-14-2013, 08:26 AM   #1
jrhaelig
jrhaelig's Avatar
Default Battery Quick Disconnect - Available - you pay shipping only
Just kidding -
Given the undecidedly negative opinions of the device that appear below I thought I would hide my un-educated purchase by giving it away.................
Original post:
I've never used one of these before.
On a positive ground setup - which terminal do you put it on?
When you disconnect - do you just loosen the green knob or do you unscrew and separate it?
Thanks again....
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 04-14-2013, 08:34 AM   #2
Pat/Ohio
Pat/Ohio's Avatar
Default Re: Battery Quick Disconnect
John, When I purchased my '40 Conv. it had one of these disconnects installed. I believe it was installed on the negative post. A word of caution...I noticed a big drop in juice to the starter when using this type of disconnect. When I removed the disconnect from the battery and connected the cable directly to the battery, the starter turned over much faster. There are better battery disconnects available, in my opinion. Good luck, Pat
Pat/Ohio is offline   Reply With Quote
Old 04-14-2013, 08:34 AM   #3
Kube
Super Moderator
Kube's Avatar
Generally you would disconnect the hot side. In other words, the negative post.
With this type of disconnect, simply back off the green knob.
Just a word of caution for you... if you have trouble on the road (what seems like a dead battery) look at this disconnect. they are not of very good quality.
The old ones that look like this were solid brass. Those worked well. Like most things, the manufacture found a way to make them cheaper while sacrificing quality.
Old 04-14-2013, 08:35 AM   #4
39portlander
39portlander's Avatar
I have the blade style, I have them on the pos side. Unless you have a clock that you absolutely have to have running.
I'm 12V, it does not matter as long as one is dis-connected.
39portlander is offline   Reply With Quote
Old 04-14-2013, 08:51 AM   #5
ct1932ford
ct1932ford's Avatar
This should keep you busy!http://www.jalopyjournal.com/forum/s...light=positive
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 04-14-2013, 09:20 AM   #6
ken ct
They are pretty much junk. There are better ones out there. Thats why there cheap to buy. ken ct.
ken ct is offline   Reply With Quote
Old 04-14-2013, 09:35 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
Those green knob devices are good at disconnecting the battery when you want it connected, the plastic melts ---when it works you just loosen the knob, they are not designed for the amperage of a 6V system, and have trouble with a 12V system, i have fixed many cranking and charging problems by removing it, they are good for buisness, ---tow truck buisness, battery sales, light bulb sales ---even a good insurance fire repair job once
Old 04-14-2013, 01:25 PM   #8
PeteVS
PeteVS's Avatar
Default Re: Battery Quick Disconnect - Available - you pay shipping only
I have one on my old 12V car and it's been working fine for the past 8 years. It should be installed on the GROUND side of the battery. Just loosen the knob.
Old 04-14-2013, 06:49 PM   #9
34pickup
34pickup's Avatar
I bought one recently at a swap meet. They seem to be made to fit the positive terminal ok but won't tighten very well on the negative terminal which is a little smaller. Overtightening them can make them snap off.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-14-2013, 07:12 PM   #10
Shadetree
Shadetree's Avatar
I have one on both my car and truck and they work great without any issues whatsoever. So nice to be able to disconnect the battery with a turn of a knob. Other than the size of the battery post I can see no difference which one you put it on. Either one will completely isolate the battery.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 04-14-2013, 07:12 PM   #11
41ford1
41ford1's Avatar
When you take a file to that nice looking brass piece you'll find pot metal underneath. Those cheap ones aren't worth the postage. If you feel the need to disconnect the battery remove a cable.
41ford1 is offline   Reply With Quote
Old 04-14-2013, 07:39 PM   #12
Clem Clement
Clem Clement's Avatar
Maybe I should get rid of those I have. I have seen them work lose also corode. What should I look for a Carlisle?
Old 04-14-2013, 07:48 PM   #13
Tim Ayers
Same here. I had to look hard to find a US-made one, but never had an issue on a 12V battery that I had it on.
Tim Ayers is online now   Reply With Quote
Old 04-14-2013, 07:58 PM   #14
paul2748
paul2748's Avatar
I just take off the ground cable. But if you use it, put it on the ground side of the battery (positive in an old Ford).
Old 04-14-2013, 08:10 PM   #15
Henryat1140
Henryat1140's Avatar
Turning this around for a Positive spin.
IMO a battery disconnect switch is a way to generate peace of mind. When the sucker is OFF there's nothing that can catch the car afire from its own electrical system. Sleep well at night - stop worrying about that smouldering short which can not only burn up the car but the garage as well.
The device mentioned here is really junk - though as Kubes has stated they 'used to be' good and well made.
We use a Cole-Hersee battery disconnect switch rated at 250Amps @6v.
There is no power loss caused by the introduction of the switch. Ours is installed in the positive (ground) leg. We used extra heavy duty cables from NAPA.
The switch was about $25.00 and the cables about $40.
Regards
Henry
Henryat1140 is offline   Reply With Quote
Old 04-15-2013, 12:47 AM   #16
Marvin/TN
Send a message via AIM to Marvin/TN
I have one like that, haven't instaled it yet but will instal and use it.
Marvin/TN is offline   Reply With Quote
Old 04-15-2013, 05:26 AM   #17
turnpikecrusier
I keep a 1/2" handy and take off the cable and remove all doubt
turnpikecrusier is offline   Reply With Quote
Old 04-15-2013, 07:05 AM   #18
1952henry
1952henry's Avatar
Find a CAT master switch. Not only heavy duty, but has a removable key. Problem is, all CAT keys are the same!
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-15-2013, 10:00 AM   #19
keith oh
keith oh's Avatar
None of them are very practicle on 36 and befor (under the floor batteries).
keith oh is offline   Reply With Quote
Old 04-15-2013, 12:39 PM   #20
Mike51Merc
Mike51Merc's Avatar
6 Volt systems draw twice the current (amps) as 12 volt systems. If the contact surface area on this unit is too small, it might heat up and fail, and also cause voltage drops.
Mike51Merc is offline   Reply With Quote
