#25 |
If you are using an electric pump to boost the mechanical on startup, I suggest using the Facet pump, Made in the USA for aircraft. The pumps output pressure is electronically controlled to stay within a specific range, for example part # 40163 is rated at 1.25 to 2.4 PSI, at 17 gph. $33.00 from Aircraft & Spruce. Made by Purolater in NY. Excellent tech help.
