Originally Posted by dmaxweb
Can you drive out the shaft through the bell housing inspection plate opening in the floorboard?
While it is doubtful that you could drive the shaft out through the inspection hole, it may be possible to fabricate a slide hammer to attach to the shaft on the outer end and get it out that way. I have not tried this method, but I would try this before disassembling the bell housing from the flywheel housing. You can always do that as a last resort. Good luck. Don/WI
