08-12-2010, 06:28 PM | #1 |
carb rebuild question
Took the old carb apart and cleaning it up. I want to drill out the brass plugs to clean the passage's. What size drill bit's are needed for the four plugs???? I know there are different sizes. Thanks to all that repley, Dennis/CT
08-12-2010, 06:56 PM | #2 |
Re: carb rebuild question
Order you new plugs and then you will know the correct drill bits, when you drill them out you will start with a smaller bit and then strep up to a bigger size until the plug spins out and it will spin out easy once you have a big enough drill size.
08-12-2010, 11:26 PM | #3 |
I think I remember the plugs are larger than the passages so they only go in a little distance, and expand to seal the passage. What I'm trying to say is be careful when you drill out the plugs, so you don't destroy the shoulder. bob
08-12-2010, 11:29 PM | #4 |
Also, don't use a drill on the idle jet circuit. If you chase the passage with a drill bit do it by hand only. If you damage the keyhole in the carb throat for the idle circuit you won't repair it very easily. Bob
08-12-2010, 11:34 PM | #5 |
