If you are running orignal type points, check to make sure that the copper strap that follows the flat spring is not too long and shorting to the case. I had this problem and it was not easy to find, simple to fix, just put a bend in it to use up the slack.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
