Old 12-01-2012, 02:22 PM   #1
jkeesey
jkeesey's Avatar
Default Cheap Internal Upgrades?
So ive found that the top end of my 1940 v8 needs a complete overhaul. the bottom end so far looks good though. Does anyone know any cheap upgrades that would work for the top end? Say pistons from another engine that fit? Anything really just want to hear some options. Im going to have to resleave the cylinders so thats not a big deal.
jkeesey is offline   Reply With Quote
Old 12-01-2012, 02:25 PM   #2
Mike51Merc
Mike51Merc's Avatar
Default Re: Cheap Internal Upgrades?
Another engine? Why another engine?
Mike51Merc is offline   Reply With Quote
Old 12-01-2012, 02:35 PM   #3
Ol' Ron
Ol' Ron's Avatar
Yes, go to 3 3/16, mill the "A" heads for .040" piston to head clearance. Very inexpensive up grade and a major increase in torque and economy. Make sure the dist is operating properly and tune the engine with an A/F meter.
Old 12-01-2012, 03:46 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Do as OL'RON says. It make a nice little engine. Remove the sleeves and bore it another .045 to 3-3/16 std. If it's really a shoe string job somebody probably has a good used set of std. 8BA pistons. Walt
Old 12-01-2012, 04:35 PM   #5
jkeesey
jkeesey's Avatar
It is a shoe string job since its my own. Mike the reason I said from another engine is ive heard of guys running 283 Chevy pistons in their Model As and wasn't sure if there was some kind of upgrade like that for a v8. Thanks Ol Ron that sounds like a good setup. As far as the dist. I got a 11A I believe it is which is mint NOS Ford rebuilt that I'm gonna put on it. And thanks Walt I'll see if I can find a set of used 8bas, they fit the 3 3/16?
Old 12-01-2012, 05:01 PM   #6
Bill S
Ron
Don't you need a oxygen sensor for a A/F meter?
Bill S is offline   Reply With Quote
Old 12-01-2012, 05:06 PM   #7
jkeesey
jkeesey's Avatar
Surpirsingly I actually have an old Sun diagnostic machine so I have a way to test the A/F ratio.
Old 12-01-2012, 07:47 PM   #8
Ol' Ron
Ol' Ron's Avatar
Yes a wide band O2 sensor is the best way to go, but I've used thise exhaust pipe sensors and they work pretty good just slow and some are static. You need one you can drive around with.,
Old 12-01-2012, 11:39 PM   #9
Henry/Kokomo
Henry/Kokomo's Avatar
jkeesey - I'd suggest that you might want to have your stock distributor set up professionally and the advance curve checked, etc. Small changes here along with a compression and displacement boost will really make a nice running engine. FWIW
Henry/Kokomo is offline   Reply With Quote
Old 12-04-2012, 12:45 PM   #10
pauldeborr
pauldeborr's Avatar
Anybody putting O2 sensors on a flathead is an idiot in my opinion. Just don't seem right.
pauldeborr is offline   Reply With Quote
Old 12-04-2012, 01:56 PM   #11
flatjack9
flatjack9's Avatar
Opinions are like #ssholes, everyone has one. I think you should have kept yours to yourself.
Old 12-04-2012, 02:01 PM   #12
Kaonix
Kaonix's Avatar
Anybody putting a flatbed on a classic ford truck is an idiot.....just because u wouldn't do it doesn't mean its wrong for someone else to. An O2 sensor gives u tuning accuracy. Who's the idiot.
Kaonix is offline   Reply With Quote
Old 12-04-2012, 02:06 PM   #13
Bassman/NZ
Bassman/NZ's Avatar
This ^^^^^^
Bassman/NZ is offline   Reply With Quote
Old 12-04-2012, 03:59 PM   #14
Ol' Ron
Ol' Ron's Avatar
guess I'm an idiot.
Old 12-04-2012, 04:06 PM   #15
Frank Miller
Frank Miller's Avatar
How does this AF meter on a flathead work? Is it permanantly installed? Does it need 12 volts. I know one is not needed but once you make the smallest modification you admit it could be better and after that there really is no line.
Ron, if you have a minute to take your idiot hat off an answer my question I am sure more than just me would appreciate it.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 12-04-2012, 04:07 PM   #16
jdl
jdl's Avatar
Send a message via ICQ to jdl
Originally Posted by Ol' Ron View Post
guess I'm an idiot.
Ron, just keep on doing what you are doing. I enjoy your posts and respect your knowledge and have learned a great deal from you.
please keep us updated.
jdl is offline   Reply With Quote
Old 12-04-2012, 04:43 PM   #17
jkeesey
jkeesey's Avatar
Anyobody calling Ol' Ron an idiot obviously has been around here very long. The 02 sensors ive seen are 12 volt and you can get them from the Sunpro company and many others.
Old 12-04-2012, 05:36 PM   #18
Butch11443
Butch11443's Avatar
Guess I'm an "idiot" also. Putting an O2 sensor & gauge on the flathead was one of my best improvements.
Butch
Butch11443 is offline   Reply With Quote
Old 12-04-2012, 06:34 PM   #19
Henry/Kokomo
I'll join the crowd. Put a modified 8ba in my '46. When back on the road, it will have an A/F meter for tuning purposes.
Old 12-04-2012, 06:40 PM   #20
tom/illinois
I too would like to hear more about o2 sensors and A/F meters.
tom/illinois is offline   Reply With Quote
