I have a recently rebuilt 289 in a '66 Mustang. The 3 core radiator and water pump were new when I installed the motor. The motor ran between 180-190 degrees. After a few months the temp started creeping up. I checked the fluid level and saw rust debris in the radiator clogging the cooling passages. I took the radiator out had it taken apart and cleaned, drained the motor and put new coolant back in. Now six months later I have the same situation. Any suggestions on how to get fix this?
Who rebuilt the engine? Sounds like they didn't flush the block after it was cleaned.
The guys on the early V8 forum have this solution. Drain the radiator, and both sides of the block. Flush with clear water and drain. Fill the entire system with white vinegar, put the cap on and take the car for a thirty mile drive. Drive home and drain and flush again. This time the crud should be gone.
Merlin, I agree it was not cleaned properly before assembled. I guess that is what I get for a buddy with a machine shop deal. I will try the white vinegar idea, thanks. Wait a second this isn't a new guy prank is it?
You could try wood bleach, which is oxylic acid. This acid was used as a radiator flush years ago. I understand GM dealers still use it. It is available at home improvement stores.
I dig coal, which provides motivation for EVs. |
Now I can go back to work on the Starliner.
Fan shrouds are worth their weight in gold ! They make a huge difference in air flow . I have one to put into my 55 Ford when the new engine goes in . I also have an electric fan I thought about installing on the grill side of the radiator with an on/off switch under the dash as a back up if I get stuck in traffic and the temps start going up . You really won't see it unless you will be looking for it .
Just an idea . Jim |
Glad to see ya got it worked out.
If you are one of those guys that like to show how slow your engine will idle, YOU could be the problem ! You will have heating at idle. Most guys do run their idle too slow.
At slow idle, the water pumps hardly pump water at all. Also, the fan is not pulling in as much air. Just try speeding up your idle and your problem might be solved. MIKE
I think I have the problem solved. The motor is a stock 289 2V except that it has dual exhaust. The car is my teenage sons first car so I did not want to give him to much horsepower. The in gear stock spec for an automatic is 475-500 rpm according to the Ford manual. So at 600 rpm it is a little higher.
What did you use to clean it?
#13 |
I used the white vinegar idea that Ole Don threw out.
