Old 11-20-2012, 09:20 PM   #1
Ole Lou
Default Assembling front axle on 32
Is there a front and a back orientation on the beam of the axle, in other words does it matter which side of axle faces forward?
How tight are the perch bolt nuts tightened before lining up cotter pin?
Thanks
Ole Lou is offline   Reply With Quote
Old 11-20-2012, 09:51 PM   #2
Fordors
Default Re: Assembling front axle on 32
You will find this thread helpful-
http://www.fordbarn.com/forum/showth...466#post505466
Fordors is offline   Reply With Quote
Old 11-21-2012, 06:02 AM   #3
2935ford
2935ford's Avatar
Stock axle? There s/b numbers stamped on one end of the axle.....that s/b on the left(drivers side) is my understanding.
2935ford is offline   Reply With Quote
Old 11-21-2012, 08:34 AM   #4
Ole Lou
Thanks, I set mine up with the numbers on the drivers side
Old 11-21-2012, 12:42 PM   #5
DavidG
DavidG's Avatar
It makes no difference which side the numbers are on especially since many of the original axles have no numbers forged into them. An original axle is straight and symmetrical.
As for perch pin nut torque, try to get a minimum of 50 pounds of torque (while lining up the slot in the nut with the hole in the spring perch pin for the cotter pin).
Old 11-26-2012, 01:43 PM   #6
Bruce Lancaster
Numbers found in ends are actually the Ford steel grade used...all the V8 ones I have seen are like EE-##. The EE is a grade of electric furnace Ford formula steel (the main ingresients are in the Ford Metallurgy book) and I suspect what follows may refer to the specific heat treatment used...the book gives one EE heat formula but implies there were several.
On a dropped axle, the EE is stretched into a sort of drunken sprawl...
Old 11-26-2012, 02:35 PM   #7
Ole Lou
thanks everyone for the responses
Old 11-26-2012, 08:55 PM   #8
296 V8
Having personally worked on several hundred ….. here is the deal.
You will probably find the lock pin will only go in from one side most of the time.
I believe this is because of a bit of a bur that develops from the nut.
If you simply clean the hole with a 9/16 drill bit … the pin will go in from either side and all will work just fine.
Some people will insist the hole is tapered and or ………………………………........ The truth is the only taper involved here is on the lock pin itself.
296 V8 is offline   Reply With Quote
Old 11-27-2012, 01:45 AM   #9
Hotrodvideo
Hotrodvideo's Avatar
My '32 axle had a letter U stamped in the front so I just put it back together the same way.
Hotrodvideo is offline   Reply With Quote
