Old 11-26-2012, 08:38 AM   #1
Chris Marshall
Chris Marshall's Avatar
Default Hubcap removal on '40 pickup - question
I just brought home a new toy - a '40 pickup with an older amateur restoration. Not a show car, but will end up being a driver. It's been sitting for over 10 years so of course the brakes are stuck, fuel system needs cleaned, etc. This truck has hubcaps, inner wheel covers, and outer trim rings. I've not seen a set of the inner wheel covers before. I'm concerned about denting/bending the inner wheel covers when removing the hubcaps as any prying will be against the wheel covers. Is there anything special here or am I just worrying too much?
Picture of the wheel with covers:
Picture of the pickup:
Chris Marshall is offline   Reply With Quote
Old 11-26-2012, 08:44 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: Hubcap removal on '40 pickup - question
My '40 pickup doesn't have any extra trim, but I can remove the caps by using a plastic squeegee and working it around the edge and it comes off with out any damage. The tapered edge lets me shove it in and gradually shove the cap outward until it comes off.
Cecil/WV is offline   Reply With Quote
Old 11-26-2012, 08:46 AM   #3
mike42
mike42's Avatar
Nice truck to sit around for 10 years ! Wow....sweet ! How many miles on it. I would love to find one like that. I have a '40 Sedan that sat around for about that long, but always wanted a pickup.
I use masking tape or duck tape in the area of wheel that I'm going to prey on to pop the trim and cap. Seems to work well and no marks. Just do it slow.
Thx....Mike42
mike42 is offline   Reply With Quote
Old 11-26-2012, 08:54 AM   #4
TomT/Williamsburg
TomT/Williamsburg's Avatar
I wrap a towel aroung the end and shaft of a screwdriver, pop the trim ring, then tap gently to pop the cap off. Before putting it back on I always put a little grease on the rim nipples to make next removal easier.
TomT/Williamsburg is offline   Reply With Quote
Old 11-26-2012, 10:47 AM   #5
Flat Ernie
Flat Ernie's Avatar
Tougher with the trim rings. I like them - even if they're too 'flashy' for some. Perhaps you may need to take a wide flathead screwdriver, heat the tip and bend it down so you can pull straight out rather than pry....
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 11-26-2012, 11:14 AM   #6
Mart
Mart's Avatar
Lots of late model cars have a plastic wedge/prybar on the other end of the wheel nut wrench for popping the center caps off. I just changed a wheel on my 01 Focus today. that plastic wedge would work well in that application. Wrecking yards are probably full of em. You might even have one already on another car.
Mart.
Old 11-26-2012, 12:03 PM   #7
Mike in AZ
Mike in AZ's Avatar
very nice pickup....Mike
Mike in AZ is offline   Reply With Quote
Old 11-26-2012, 02:09 PM   #8
Chris Marshall
Thanks for all the kind comments regarding the pickup. I've had a project '40 pickup for almost 30 years and haven't gotten to it. When this one became available, it was a much faster road to having one of my "top ten" vehicles running/driving. The project truck will likely be for sale soon!!
TomT opened my eyes on this. I thought the center hubcap held the inner trim ring in place, but that is apparently not the case. Since the inner trim ring comes off before the hubcap, it's simply a matter of carefully popping off the inner first. I appreciate all the helpful insight.
Old 11-26-2012, 03:30 PM   #9
RPM
The hupcap is what holds the inner beauty ring on. I use an old brake adjuster tool and beginning at 12 o'clock, I insert (or wedge it) straight down between the cap and ring. Then I gently pull the tool outwards while holding cap with my other hand. The cap will POP right off. There will be very negligible damage to the inboard flange of the inner beauty ring, but it will be covered by the cap when everything is reinstalled. PS__the inner ring has some razor sharp edges that can cut pretty deep if not careful. Ask me how I know. RPM
RPM is offline   Reply With Quote
Old 11-26-2012, 04:20 PM   #10
Fibber Mcgee
Fibber Mcgee's Avatar
Who on earth would let that sit..... that truck is to beautiful to sit,she needs to be shown off. That's like being married to Betty Grable and making her stay home everytime you go out.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 11-26-2012, 04:44 PM   #11
4dFord/SC
4dFord/SC's Avatar
I'll second ttthat-sttill having troble using fingers after installinnng mine
4dFord/SC is offline   Reply With Quote
Old 11-27-2012, 08:08 AM   #12
Chris Marshall
As a followup - I pulled one of the hubcaps and inner trim rings off yesterday evening. Getting the hubcap off without denting/scarring the inner trim ring is a delicate operation to say the least. I used a wide blade screwdriver with a leather work glove as a cushion on the inner trim ring to pop the hubcap. As an education to those that haven't seen or installed these inner rings (including myself) the inner goes on the wheel first and is held in place by clips on its outside diameter. The hubcap goes on the wheel last and overlaps the inside diameter of the inner trim ring by roughly 1/8". FWIW these are late 70's/early 80's Argentina reproduction parts. Originals may fit differently? A couple pictures:
