Old 11-22-2012, 11:12 PM   #21
Fibber Mcgee
Fibber Mcgee's Avatar
Default Re: 6 volt change to 12 volt (pros and cons)
Originally Posted by Fartman View Post
Thanks for all the info Guys,I will be using this car as a daily driver,if i change to 12 volt will i need to change the starter motor,generator,plus other parts?.
The starter motor can stay the same. As others said it might be hard on the ring gear but I've been running my 6 volt starter 12 volts for a couple years with no problems.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
