#18 |
What you may be remembering is that the old radio will work with negative ground (not 12 volt) if you replace the old vibrator with a new one that is not polararity sensitive. That's as close as I remember anything related to that.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
