Old 08-30-2012, 06:30 AM   #12
Russco
Russco's Avatar
Default Re: Oil Pressure question on new 8BA
Originally Posted by Karl Wolf View Post
Just a thought... I had a popular, well known vender send me a cam that had .010 undersize journals... With standard size cam bearings. I check stuff pretty well, and have installed plenty of cams so I know how it should feel- But I don't remember how I found this...
Point is, how are your cam bearings?
(Avatar) Hot idle, 59AB, 8BA oil pump (salvaged from a runout engine) a bit over 35 lb., hot running holds at 62-3 lb...
Karl
I thought of that too. My cam was ground at Delta and the card didnt have much info just the lash,grind number and opening and closings points to check so I called them they said unless other wise specified they would be standard. So I am assuming thats not the issue and it certainly didnt feel at all loose when I installed it.
Life is hard, after all it kills you!
Russco is offline   Reply With Quote
