Old 08-29-2012, 03:34 PM   #21
Rowdy
Default Re: gleaner combine
Interesting that one is chain drive, most I see are belt driven. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-29-2012, 05:01 PM   #22
Brobrian
Brobrian's Avatar
Got one out of my Granddad's Gleaner all ready to go in one of my A's. I thought a major difference in these engines was the cam. Something called an industrial cam, which I assume is a certain lift and duration that would suit their use. We just left the cam in it, so part of the fun will be finding out how it runs in a car.
Forty horses is plenty.
Brobrian is offline   Reply With Quote
Old 08-29-2012, 05:12 PM   #23
TinCup
TinCup's Avatar
Just got my gleaner motor to finally turn over. It looks surprisingly good for sitting covered with dirt for over 10 years.
TinCup is offline   Reply With Quote
Old 08-29-2012, 05:17 PM   #24
John Stone
John Stone's Avatar
If it was a diamond block, it will have a B cam if not messed with over the years. Otherwise, it will have a standard A cam.
John Stone is offline   Reply With Quote
Old 08-29-2012, 08:54 PM   #25
Purdy Swoft
Purdy Swoft's Avatar
Is that the 339 lift version?
Old 08-29-2012, 09:49 PM   #26
Brobrian
Brobrian's Avatar
Hmm, wonder what the differences would be. Guess I'll have to drop it in an A to find out.
Old 08-29-2012, 11:01 PM   #27
Rowdy
One of the B style cams out of one of my diamond blocks has a number stamped in the end. I asked about the number on the old Fordbarn and no one knew what it meant. The number started with a G, so I presume that to mean Gleaner, not sure what the rest of it stood for. Rod
Old 08-30-2012, 10:07 AM   #28
John Stone
John Stone's Avatar
As near as I can tell from the parts catalogs, Ford didn't make a special cam for the industrial engines. At the end of the A production, they discontinued the A cam and only supplied only one version of the B cam. They recommended replacing the lifters with the slightly larger mushroom of the B style.
