Old 08-20-2012, 08:06 PM   #1
robert dick
Default "best" head gasket
does anyone have a good method for removing Best brand graphite head gaskets from aluminum heads, i have tried several gasket removers , even heating the surface with a propane torch, nothing seems to work !
robert dick is offline   Reply With Quote
Old 08-20-2012, 08:14 PM   #2
wga
wga's Avatar
Default Re: "best" head gasket
I used a CRC product - Gasket Remover, and spray on paint remover - the epoxy kind. It softens them a bit. Needs to be kept wet, and soak. Used a right angle CP grinder with a 3M Scrotch Brite eon a mandrel, and went along very very carefully and just kissed the surface.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 08-20-2012, 09:43 PM   #3
4tford
4tford's Avatar
I use a sharp edge putty knife to get under the gasket and carefully scrape it off then the angle grinder with a soft wire wheel
4tford is offline   Reply With Quote
Old 08-20-2012, 10:12 PM   #4
Ronnie
Ronnie's Avatar
http://www.henkelna.com/cps/rde/xchg...UID=0000000IA3
Ronnie is offline   Reply With Quote
Old 08-20-2012, 11:08 PM   #5
ford1
LOL, two things wrong, dont use aluminum heads, and never use composition gaskets, and you just found out why
ford1 is offline   Reply With Quote
