My 38 runs well, however when I start the engine wet black soot shoots out the exhaust pipes. It makes a mess in the driveway. No drop in coolant or increase in oil. No gray smoke in exhaust. It does seem to be more than condensation. What is it?
Since your not loosing coolant, the water has to be condensation and the black soot is most likely a rich burning condition. Pull several plugs and check for the soot deposits on them. If you baby the engine a lot or the carb has problems, the soot can build up. Depending upon the moisture in the air the there can be a lot of condensation.
i had that till I blew the carbon out of her. rich idle condition contributed greatly. Ken ct rebuilt the carb. It was after that the soot quit showing up. I do run 100 miles a week at highway speed, 60-65. as for the water you can put 1/8 holes at the exhaust low point etc. but I'm not seeing that either anymore and I didn't drill the exhaust..
Put a large bottle of Barr's heavy duty aiuminum stop leak in and it will stop. G.M.
www.fordcollector.com |
Barr's stops condensation in your exhaust? And carbon from a rich mixture?? ..B.
I have LOTS of old Fords and most did this and the Barr's stops it. On a cool day you will get a little condensation but what was described is a typical small leak. This mixes with the carbon in the pipes and muffler and makes the black mess. G.M.
If you're running too rich, do you turn the jets in or out?
the idle mixture screws ... in leans them out I think. I never got it right and finally had an old t-bird guy do it. he didn't say what he did but its perfect and so I ain't even looking at them. Somebody else here knowsd way more about it than i do. I think proper timing for your setup will make a big difference too.
Set with vacuum guage. Rather than type it all, I pasted this.
http://www.chevyhiperformance.com/howto/45638/
I dig coal, which provides motivation for EVs. |
Aren't the idle mixture screws strictly for what they are called? Adjusting the idle. If you are running rich I would think that means you need to change your jet size or your choke is not open all the way. ?
#13 |
#14 |
Water is one of the products of combustion, and is most noticeable before the engine gets to operating temperature. It is still present at operating temperature, but not as a liquid. Warmup on choke adds the carbon, thus the typical driveway mess. Use thermostats and warm it up on the road. ..B.
#15 |
#16 |
Don't forget, Barrs Leak and MMO will fix almost any problem on a flathead.
#17 |
just curious about how long you are running your engine....trips??....getting engine temp up to normal and running it that way for a while??....thanks....Mike
#18 |
tom b
take off aircleaner. start engine. look down carb and make sure you don't see gas pouring into engine. that's stuck float. use a bright flashlight and safety glasses, in case of backfire. bye
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 08-19-2012 at 12:42 AM. |
#19 |
#20 |
In..! If your still fouling plugs,rebuild the carb.
