Old 07-20-2010, 10:05 AM   #9
Bob A.
Default Re: Can't seem to find the problem
Maybe the heat has nothing to do with the problem. If this car is running a repo. ignition switch, start there by jumping it and see what happens.
When I first got my car it would run fine then cut out with a backfire. Turned out to be a bad ignition switch. Nothing like getting stuck on the road and making a quick repair to get home.
"Some Talk the Walk while others Walk the Walk"
Bob A. is offline   Reply With Quote
