Does anyone know where new ( or good used) top motor drive cables for a '53 Merc can be had?
Try Hydro-E-Lectric in Punta Gorda, Florida. Sorry, I don't have there phone number but I'm sure they have a web site.
Imagination is more important than knowledge. |
When you say "drive cables" .....they look to be heavy spedo cables....
They are probably more similar to Teleflex cables used for steering & control applications for boats. I know you can get stuff for marine applications that may have a cross over in size and strength to the old power top drive cables.
If Hydro-E-Lectric can't help, you might call this outfit. http://www.convertibleparts.com/index.htm They make drive cables for the 71 to 76 GM products that used similar drive set ups. The key would be a company that has the right size cable and a way to swage the drive ends to a shape or fitting that will work for the Mercs that used them for a time. Last edited by rotorwrench; 06-11-2012 at 05:41 PM. |
