Old 03-04-2012, 07:18 PM   #1
Chris
Chris's Avatar
Default Fired my flathead today for the first time!!!
I have been building this lil engine for a while to go into my 34 Ford. My Dad is a heck of a flathead guy and helped me do it right. Today was the day for the first run. It lit right off and sounded great!! Had great oil pressure and ran cool (has Skip's pumps on it!). Heck it even charges! Broke it in and that was that. Gotta sink the carbs but otherwise I think she is well on her way! Thanks a ton to my Dad Dave, he is a true craftsman!!!
It's a 59AB with a Merc crank, Windfield SU-1A cam, Edmunds heads and a Thickstun PM-7 and dual 97's.
Sorry for the grainy video, but the sound is there
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 03-04-2012, 07:41 PM   #2
39portlander
39portlander's Avatar
Default Re: Fired my flathead today for the first time!!!
Nice sounding Flathead Chris, hope to get mine runnin by April. Nice to hear your runnin skip's pump's
39portlander is offline   Reply With Quote
Old 03-04-2012, 08:44 PM   #3
G.M.
Chris, Looks good but I don't see any fan or do you have an electric one in front of the radiator?? I also see the high risers on the intake which should keep the carbs cooler and the fuel lines up high away from head and block heat. G.M.
www.fordcollector.com
Old 03-04-2012, 08:52 PM   #4
Old Henry
Old Henry's Avatar
Here's mine starting after sitting 31 years with nothing but an oil change, cleaned up carb, and new battery:https://www.youtube.com/watch?feature...389S_KUjs&NR=1 You can skip the criticism of me "trickling" gas in the carburetor to get it going. I've heard enough of that.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is online now   Reply With Quote
Old 03-05-2012, 06:14 AM   #5
PeteVS
PeteVS's Avatar
I think that I read that that other Henry guy had his WIFE trickle the gas down the carburetor during the initial run. Seems like a good way to avoid getting burned yourself, and, it would be a time honored tradition seeing as it's the way the very very first Ford was fired up.
Old 03-05-2012, 12:59 PM   #6
peewee2you
peewee2you's Avatar
Old Henry, looks like it was a family affair, very cool. Is that the same 47, in the photo's
in the fancy garage, where the family parties take place, when needed? The same one that got hit buy the duellie.
peewee2you is offline   Reply With Quote
Old 03-05-2012, 01:04 PM   #7
Old Henry
Old Henry's Avatar
Yep. Same one. Here's the video of it's first movement under it's own power not long after we got the engine going: https://www.youtube.com/watch?v=LBe8K...99FAAAAAAAAAAA
Since then it's gone 30,000 miles on the road including Route 66, Pike's Peak, Death Valley, and probably about 15 miles a day just joy riding. What a joy. But, really, part of the greatest joy was the year I spent working on "Old Henry" with my 15 year old son shown in the video behind the wheel. When we were done I said more than once that if we just ran the car into the lake it would have been all worth it just to have that experience with my son. He was the last of my 10 children and I tried to have that same kind of meaningful experience with each of the 10.
Old 03-05-2012, 02:03 PM   #8
Mart
Mart's Avatar
Chris: The motor sounds great!
I saw the buildup pics, your Dad did a fantastic job.
Henry (sorry for the post hi-Jack, Chris) I saw that video a couple times, I feel like I "know" you now. LOL.
Mart.
Old 03-05-2012, 03:34 PM   #9
Chris
Chris's Avatar
Thanks guys...now gotta get the rest of the ol buggy done!!!
Old 03-05-2012, 05:29 PM   #10
2935ford
2935ford's Avatar
Sounds Great Chris!
2935ford is offline   Reply With Quote
Old 03-05-2012, 06:16 PM   #11
Old Henry
Old Henry's Avatar
I guess that could be good or bad.
Hope it's good.
Old 03-06-2012, 10:46 AM   #12
Gumpy
Gumpy's Avatar
chris and henry thanks for sharing your startups! gump
Gumpy is offline   Reply With Quote
Old 03-09-2012, 04:28 PM   #13
37slantback
I plan to fire mine by the end of the month. Howard cam, offy intake and heads, merc crank, and dual 94s.
37slantback is offline   Reply With Quote
Old 03-09-2012, 06:36 PM   #14
Chris
Chris's Avatar
Well, theres more to the story. Day after I fired it for the first time I lit it off again. It spit a shot of water out the passanger side header. Pulled the plugs on that side, shot water out the number 2 cylinder. Hmmmm....pulled the head and found a crack in the Edmunds head:
I had the heads milled and the cracks were not there. I torqued them to 30, then 50 in the right sequence so I do not know what caused the crack. My Dad had a magentis dial indicator and we ran the numbers on all 8 clinders to measure how far up they came above the deck...making sure the rod did not bend. It was fine
My Dad also had a set of new Edelbrock heads in the box. I like old origianl speed equipment...but this is the 2nd set of old heads that have gone sour so I "borrowed" them from him. Back to running like a champ, only not as a water pump
Click for video
Old 03-09-2012, 06:45 PM   #15
37slantback
Damn Chris, sorry to hear that. You are a lucky guy to have your dad around there.
Old 03-09-2012, 08:45 PM   #16
Hank the 36
Hey Chris, I've really been enjoying your build thread on the HAMB, best of luck to you and your dad sounds awesome.
H36
Hank the 36 is offline   Reply With Quote
Old 03-10-2012, 05:03 AM   #17
Mart
Mart's Avatar
Glad you found the problem so quickly and not one the side of the road 1000 miles away. Do you think the head can be repaired?
Mart.
Old 03-10-2012, 10:42 AM   #18
Chris
Chris's Avatar
Mart.
Probably but my question is why did it crack? I know it was not over tightened...bad casting? Will it crack again?
Old 03-10-2012, 02:08 PM   #19
bk53
Bro. that's a beautiful thing you are doing. Flatty sounds sweet. sorry about the head.
I checked out a Thee Inland Emperors video on you tube. Young dudes with a passion for flatty's. I thought there is hope for this world yet. Then I watched the rest of the video.... Just kidding. I loved your ride.
My pal Nordy is near Spokane. Drives a 32 Henry PU with tons of patina.
Bill,
Rowlett Tx
bk53 is offline   Reply With Quote
Old 03-10-2012, 09:35 PM   #20
37slantback
I was thinking of your "incident" when I was torquing the Offys today.
