#101 | |
Wow, it ONLY took you forty-five years to know the difference... Look a little closer at the photo I posted, if they really are "rust pits" wouldn't it stand to reason that the "banjo” as well as the spring perches would also be pitted...? Something more for you to ponder.
Imagination is more important than knowledge. |
#102 |
In NJ is is not uncommon to find pits in the axle housings. NJ is damp in the summer and salt is used on the highways all winter long. The center sections are usually smooth because the oil leaked out of the housing and gave it a nice protective coating. The leaking oil also protected the ends of the axle housings from rust and it is not uncommon to have smooth areas on them.
#103 | |
. I owned several '30's and '40's vintage Flatheads while I lived there and never saw a rear that was as "textured" as the Columbia I have. The Zephyr was also a LI car from new and the rear we pulled out has a smooth finish as does our '39 Ford CS, also a LI car. It is a conundrum however, based on the limited information I've been able to obtain, I know for sure that the "Columbia" side of the axle was in fact made by Columbia, which may or may not account for the "textured" finish ... Bottom line for me is this; I'm not too concerned with the outward appearance of the Columbia, I want the unit to function as it should because we plan to drive this car quite a bit and that includes some long road trips. She will not be a Trailer Queen.
#104 |
Super Moderator
Vic, With due respect and to offer a bit of (obviously needed) clarification I's like to reiterate in part my earlier post:
The axle housings were not CAST by Columbia. Rather, the right housing was CAST by Ford and MODIFIED by Columbia. Columbia did NOT cast axle housings. Period. When I began to read this thread I initially became interested in the "texture" as I'd not seen that before on a "restored" assembly. It had not occurred to me that you would have painted over a pitted (rusted) housing as must surely be the only plausible explanation. That is the sole reason I inquired about the "texture" in the first place. It was my mistake to assume. You know what is said about those that assume. |
#105 |
Kube, Paint over rust (your assumption) that’s very funny… in fact, I prepped the entire assembly however; I did not grind it smooth as I'm not that anal and I want function over finish in this instance (I don’t build Trailer Queens), prior to priming and painting it. Further, I talked with John Connelly of Columbia two speed Parts, Inc., he said that Columbia cast the axle housings for the conversion (my assumption is that he is correct, while it is possible that he was only referring to the right axle housing being modified by Columbia, he did not clarify that). With all due respect, where did you get your information?
#106 | |
Super Moderator
I think if you speak with John once again he will clarify what I have told you in regard to the housings. He knows me and knows the lengths I go to to research this type of thing. |
#107 |
No confusion here, I never intended to smooth the axle as it is not visible unless you are under the car and, as I mentioned, I'm more concerned with function then vanity. You didn't say where you got your information, I'd appreciate knowing as I want to learn more about the Columbia Axle Company.
#108 |
For those of you that have been following our slow but continuing progress on the '39 LZ, as well as those who like to actually drive their cars more than just on and off of trailers... Hopefully we'll be getting back to working on the Zephyr next weekend. I was hoping to have her back together and on the road for the "Barner's Bash" this weekend but we've been out of town for the last three weekends. Stay tuned as the fun will continue.
#109 |
Now that the "Barner's Bash" is over, it's almost time to get back to work on the '39 Zephyr. Here's a photo of the rear shocks
(rebuilt by Bill Wzorek) along with the correct NOS dog bones. I'm really looking forward to driving the "new" Zephyr... ![]()
#110 |
Well, I'm finally going to be home for a couple of weekends in a row, so I hope we can get some more work done on the Zephyr
. I'll post photos of the fun and hope I don't offend anyone’s sensibilities (if they don't like looking at a 72 year old undercarriage that does not shine like a mirror) . This car has been, and will continue to be, driven as much as possible, and I can't wait to get her back on the road.![]()
#111 |
We finally got a chance to get some work done on the Zephyr.
Yesterday Mike and Jeff came over and we installed the transmission and brake & clutch pedal assemblies and assorted linkage. We didn't have enough time to get the rear back into the car, that'll be the next step.
#112 |
#113 | |
but I think the Moonshine Festival is a more attainable goal.
#114 |
Put the Zephyr on the train and do NE tour. A step by step operations placard will work for the Auto Train guys. The tour is coming together and it should be good. You will like it.
#115 |
I would just let KiWi,s Towing come & haul that ol junker off so you dont have to waste time on her !!!!
He prob wont charge you to haul her off ..... jus cause he likes ya !!!! Plus that would let you spend time on that magnificent house & get his room in the house finished so he can move in !! Cheers Tony |
#116 |
Tony only haul it off if he throws in the plaid jacket!!! heh heh he
#117 |
Oh Yeah! If you come to the NE tour you have to bring that plaid jacket!!!
#118 |
Tony, all I can say is "be careful what you wish for"...
LOL. I can't believe that my jacket made such a hit with everyone... Maybe we could make it the official "Barner's Bash" Jacket... Here's another shot of me with my daughter at her wedding rehearsal.
#119 |
Lets face it. The Zephyr needs plaid seat covers even if its only temporary.
#120 | |
